| Question - Pressure drop calculations It's probably a phenomenally stupid question. Hopefully someone here can make me see what obvious thing I'm missing - knowing a question is probably stupid has never stopped me before- I just finished designing a vapor recovery system for a tank barge. 46 CFR 39.30-1 (b) says that I now need to plot the pressure drop through the system, from the most remote tank to the gate valve have on the bow, as a function of volumetric flow rate. It then says that I need to include this in the vessel's oil transfer procedures as a table or graph. So I used Crane's flow of fluids program to model the system, and plotted pressure drop vs flow rate. I understand what I'm looking at, sort of - it's like any standard pipeline resistance curve you'd find in a textbook... but what I'm trying to figure out is - who on earth actually needs to see this? What is it useful for? I can't imagine the tankerman loading the barge getting any use out of it... and I don't see how this could possibly be of any help to coast guard in figuring whether to approve/reject my design.... ... other than to prove that there is, in fact, fluid flowing through the pipe... and there is a pressure drop.... oooo........ My question - what on earth is this for?! |
| Sorry, I do not have a clue what you need it for, but "I" almost screwed up once... Or at least I used some time to see the light.... ![]() (Good thing was; I saw the light first..). A setup with a HPU (hydraulic power unit) installed with on/ off for pressure switch, hydraulic lines to the "consumers". This thingy (HPU) went on off on off on off, really bothering folk around, during testing the: control panel was ok, (I had tested it) The accumulators, were ok. ( I had tested it) the valve actuators were ok, ( I had tested it) the HPU were ok... (I had tested that too!) So why in God's name did it operate so completely silly? It took some time until I finally got an idea; asked the question how long stretches are there of piping, really... Installed, now.. Really? When calculating the flow (resistance) of the HPU, in the hydraulic lines, I found there was a pressure drop, resistance in the piping but; then the accumulators only had 180 bar, the pressure switch at the HPU had 210 bar, stopping the HPU, Starting again, stopping again, a zillion times until the accumulators were at the same pressure as the HPU. Until some silly idiot suddenly operated one valve again... The Solution were to relocate the pressure switch... Closer to the accumulators. So; a pressure drop diagram can tell you something. And it can be a tool during fault finding.
__________________ KnutS "it's dark and we're wearing sunglasses" |
| alright, thanks for that, you shed some light on the practical aspect with regards to coast guard, the only thing I can come up with is... if we assume pressure at the point of recovery to be atmospheric, it's logical that the pressure inside the cargo tank will be 1 atmosphere plus whatever the pressure drop occurred in my piping. I seriously doubt they're questioning the ability of the system to 'keep up' with the rate of cargo loading, given that one's a liquid and the other's a gas - but the smaller I make the pipe, obviously, the more the tank is stressed because the more pressure builds up inside it. so I'm going to attach a quick and dirty tank top scantling review - to show that it can handle the pressure - and send it in this is just a guess... if someone knows any better, please chime in |
| If you know the pressure drop through the system, the flow you want, gas type, density etc. you can then size the blower/compressor correctly. The vapour recovery system is probably connected to the P/V (Pressure/Vacuum) valves that limit the pressures in the tanks. These also have to be designed so that there is no uneccessary venting when the blower is running. It can also have safety aspects, to ensure that oxygen is kept out of the tanks even with a massive cool down. I hope this makes it clearer, otherwise get back to me. Regards Alan |
| Drop test | dougfrolich | Open Discussion: All Things Boats & Boating | 3 | 07-25-2007 06:58 PM |
| nikki dual float drop specs | dog face | Outboards | 0 | 04-08-2007 11:34 AM |
| Hull bottom pressure calculations | Brands01 | Boat Design | 3 | 02-11-2007 04:54 PM |
| drop leaf tables $150 each | 7393452 | Marketplace | 0 | 12-20-2006 02:47 PM |
| Details on drop and swing keel | mik lenoir | Sailboats | 3 | 11-10-2005 07:03 AM |
