Old 01-06-2011, 01:13 AM
stix stix is offline
Purchase of plans
I have a requirement for a custom built mobile pontoon that is 17m in lenght and 5m in width. Because it is a one off, the regulatory authorities will no doubt have a lot to say about it. However, I do know of one other vessel that is similar being built before, but it's not quite as large.
Do you think it is worthwild for me to get one designed from scratch, or given that most of the work has already been done and i don't want to reinvent the wheel, would it be cheaper and easier to attempt to purchase the plans off the builder of the above mentioned vessel and make some modifications to them?
Does anyone have any suggestions regarding which path I should take?
Cheers
Old 01-06-2011, 01:55 AM
BertKu BertKu is offline
Rep: 130 Posts: 1,035
Cheers
I went that route and unfortunately the additional work on re-calculating every bit of the boat is astronomical. You cannot just take the same thickness of the material, but need to either re-work some raw material or add some more layers in case of GRP. Also the authorities does not take your word for granted and like to see some proof from the builder or an independent NA/surveyor. It all boils down to cost. Time is expensive and the error rate is high. If you have lots of time, go for it. Otherwise my recommendation is to make a deal with the builder and get the right size.
Bert
Old 01-06-2011, 01:58 AM
Rep: 3125 Posts: 9,398
If your vessel will be used "for hire" then you absolutely need to have the plans drawn up professionally. It's also likely your "regulatory authorities" will ask who made the "upgrades" to a set of existing plans. Without a reasonable and respected answer, you may have some registration issues.
In short, contact the designer of the other vessel and see if they can make the changes you desire.
Old 01-06-2011, 06:40 AM
Rep: 1493 Posts: 7,447
Is this something like a floating dock? Those can be bought in sections, already approved. What is it for?
Boat Purchase just_a_plain_av Powerboats 7 11-28-2006 01:03 PM
A boat I'm considering to purchase... Seafarer24 Sailboats 7 09-27-2005 09:14 AM
looking to purchase mold brian340 Boat Molds 6 06-15-2005 09:26 AM
O/B or I/O -- Which to purchase? wazzu98 Powerboats 2 09-06-2002 01:44 AM
