Old 10-21-2010, 05:49 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Originally Posted by PAR View Post
98% of the time a cruiser is anchored, moored or berthed. Up wind work is a necessity, but it doesn't have to be a smash and bash to windward, when all you have to do is ease the sheets and make a few more tacks.
Couldn't agree with you more Paul, and under sail is a nicer ride usually, space permitting of course, but the optimum boat characteristics should be determined by how it is going to be sailed, not how it would be sailed by an expert.
Dances with Turkeys
Old 10-21-2010, 06:27 PM
Rep: 3125 Posts: 9,398
Most cruisers become fairly expert in short order. Other wise they sell the boat and by a condo with a water view.
Old 10-21-2010, 06:52 PM
RThompson RThompson is offline
Rep: 116 Posts: 141
Originally Posted by dskira View Post
You forget the strength of a long keel design. ... ...The sea is the sea, you don't have different definition of cruising, just uninformed or ignorant peoples who make the wrong decision following stupid advise.
Daniel
Good point, theres also potentially higher headroom with wine glass sections, however I wasn't trying to give an exhaustive list of benefits or otherwise of different keels - more I was pointing out how much of a compromise a keel was: "...or any combination of many different things".
Also at the end of the day a sailing yachts' keel forms a critical part of the yachts propulsive system and hence the keels propulsive performance should at least be considered, even it it is discarded or downgraded as a low priority. A yachts sailing performance doesn't have to be all about bashing to windward or racing round the cans (nothing goes to windward like a 747).
Maybe I misunderstood the statement, but surely you are not suggesting that there is one correct description of cruising followed by one 'silver bullet' cruising keel design (and anyone acting outside that description is uninformed or stupid)?
I don't think many people, certainly not me, is advocating that evry small cruising yacht should have a particualr type of keel because 'its the best'. -best for who? doing what? where?
Old 10-21-2010, 10:08 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I'm just going to add to the debate in favor of the long shoal keel, which is what my own boat has. Pointing is not her long suit but any shoal keel design can be fitted with a centerboard or a swing keel.
Mine has a decently cutaway forefoot which helps when tacking the boat. The best thing about this type of keel is the amazing tracking in most conditions and the gentleness of the helm. Beaching is possible and so is launching and retrieving single-handed (she's 15 ft and about 1300 lbs).
Another benefit is the ease of balancing the rig, or rather, the way she balances no matter whether reefed or with headsail.
Speed is not a problem. I race on Sundays throughout the Summer and I rarely finish ahead of centerboard dinghies except in very light air in which case she'll even ghost past the occasional Hobie 16. But I am not concerned since she moves along smartly enough and I don't mind losing when I know my boat has been sailed well. In that sense I tend to sail against my own average time.
I think that each sailor has his own preferred type of sailing and hence preferred sailboat type so who can say what keel configuration is best?
What matters is that one builds or buys the boat that will fulfill that preference. Knowing what a boat design will or will not do is what matters. You don't want to be stuck with the wrong boat.
Old 10-22-2010, 07:57 AM
dskira dskira is offline
Rep: 1305 Posts: 1,372
I edited you.
No you didn't misunderstood my statement.
It was a stupid statement, made in a unprofessional manner, being pissed off by this stupid conception that long keel is old fashion and nostalgic without merit.
So I apologise about that. I should know better.
Daniel
Old 10-26-2010, 02:48 PM
Rep: 116 Posts: 141
"...being pissed off by this stupid conception that long keel is old fashion and nostalgic without merit...."
No need to apologise, although it made me smile a bit in empathy -I can fully appreciate the frustration when coming up against a narrow opinion impervious to reason. Seems to be a common affliction in the world of boats
On another note, theres been no further word from Emma. She asked about keels - theres a few points to consider discussed above...
Old 10-26-2010, 05:15 PM
gunship gunship is offline
Rep: 137 Posts: 146
hmm, a question about twin keels. what makes them as effective as a single keel, the ability to hold more ballast than an equal draft single keel or something more complicated?
Old 10-26-2010, 06:37 PM
They are not as effective as a single keel in most regards. They do offer lateral resistance at typically a shallower depth then a single appendage, but at the cost of considerably more wetted surface, which means drag, which means slower.
With few exceptions, bilge keels are reserved for those that sail in wide range tidal areas, where having to take to ground is common, not the exception.
Old 10-26-2010, 11:48 PM
aka Terry Haines
Twin bilge keels can be compared to a biplane in which the greater efficiency of a monoplane is sacrificed for reduced wingspan. The biplane has the advantage of greater maneouverability especially roll rate, and a smaller hangar. Similarly, a twin keel boat can venture into shoal water and will stand up at low tide, but windward ability and some speed is lost. A centerboard, daggerboard or leeboard(s) offers a compromise but requires more attention from the crew; again the greater efficiency of the daggerboard must be set against the self-retracting capability of a pivoted board if crew attention is lacking.
A missing requirements input is expected performance. If this is desired over safety and convenience then the daggerboard is indicated. If not then the choice depends on availability, I would say, unless you are planning to build it. If there is a need for trailering and low bridges are found in the area, that might militate against the twin bilge keels.
Dances with Turkeys
  #25
Old 10-27-2010, 05:26 AM
Rep: 756 Posts: 3,328
"They do offer lateral resistance at typically a shallower depth then a single appendage, but at the cost of considerably more wetted surface, which means drag, which means slower."
True in light winds , where the usual cruiser will be using the Iron Topsail.
But Hull Speed is based on the LWL, not on the appendages , so the boat will still have the same TOP speed (it will just take more breeze).
FF
swing keels :pros and cons souljour2000 Sailboats 36 12-01-2009 09:28 AM
Pros and Cons of jackshaft power. Capt Sport Metal Boat Building 65 05-03-2007 08:11 AM
Jackshaft pros and cons Capt Sport Boat Design 2 03-31-2007 04:40 AM
Stepped hulls pros and cons AdrianRO Powerboats 8 11-24-2006 06:43 AM
Pros and Cons of an I/O system shadowrack Powerboats 5 02-17-2006 08:11 PM
