| Propulsion question please help I am curious as to if anyone has ever used a Voith Schneider propeller in a small application, like on a small less than 16ft. inland fishing boat, and if it is possible to do so. I am trying to figure out a way to power a small boat in very shallow water without having motor drag. Please offer suggestions, pictures or websites. I would prefer electrical propulsion. Thanks. |
| If you're going to move something in a fluid you will have drag. I believe Voith-Schnieder propellers have been built for model boats, but they are considerably more complex than a standard shaft drive. By comparison, even a contra-rotating Z drive looks simple. My advice would be to use an electric outboard. It is a simple, self-contained unit. If you feel like stepping up the tech another notch, something like an electric version of Volvo's IPS might work. It depends wha you're after. Tim B.
__________________ Open Source Marine Charting - openpilot.sourceforge.net Supported by engineering.selfip.org |
| The Voith-Schnieder is definitely not the right drive for either shallow water or a small boat. Complex, expensive and you would not want to deal with running aground, even just a little bit. A tunnel drive may be your best bet. Flats boats use tunnels and a jack plate for very shallow water. Robb White's inboard tunnel drive skiff "Rescue Minor" is said to run in 6" of water. http://www.robbwhite.com/rescue.minor.html A jet is also an option. You can get jet drives on outboards too.
| Propulsion | DEDave | Boatbuilding | 7 | 02-20-2009 12:52 AM |
| Propulsion question (featured on History Channel) | justinDesign | Boat Design | 7 | 10-20-2006 05:00 PM |
| Flapping Propulsion. | kjell | Boat Design | 25 | 01-02-2006 06:19 PM |
| DC propulsion | DGreenwood | Electrical Systems | 5 | 01-12-2005 01:47 AM |
| v-drive propulsion question | jetkibby | Boatbuilding | 1 | 08-11-2003 11:53 AM |
