Old 10-26-2004, 05:47 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Propeller sizing...
Hello...
Just bought a used (120 hrs) 8 horse long leg Evinrude for my O'day 22 - it has a 12/8 prop on it and pushes me to hull speed at less than half throttle...
Guy I bought from used as kicker on a planing power craft...
Lots of wash on the rudder - motor on good bracket to starboard of rudder and prop rotates clockwise - when I open it up the wash gets ridiculous and some vibration sets in...
I mic'd the shaft - was never hit - I think going to a 10/7 will help and I have a dealer who 'just happens to have one on the shelf' - yeah for how long and why...
Smaller diameter - more rpms (better for motor) - mid pitch - good push...
Before I lay out for the prop what do you guys think...
Thanks in advance...
Old 10-27-2004, 11:49 AM
artemis artemis is offline
Steamboater
Rep: 267 Posts: 411
If you're up to hull speed at half throttle then you are not effectively using the HP you have - i.e., you've got too much for the size prop you're swinging.
I'd suggest using a larger diameter prop - if possible. This is the best way of "using up" HP. You'll then probably have to adjust pitch. David Gerr has some excellent prop calculations in his "The Nature of Boats".
bigger props faster ship? Peter H Boatbuilding 23 02-01-2010 01:08 PM
Propeller Seminar accredited for Continuing Education credits D MacPherson Education 1 06-30-2005 11:42 PM
Propeller sizing and engine loading E4ODnut Props 3 12-29-2004 05:50 PM
Inboard Propeller sizing / theory ?? jav Props 22 12-10-2004 10:49 PM
Analytical propeller theory Guest Boat Design 8 11-12-2003 02:57 PM
