Old 09-20-2003, 07:40 PM
kapnD kapnD is offline
Rep: 14 Posts: 113
prop pocket or delta section?
Which would be more effective means of achieving vertical prop clearance? Hull is 29'x9' fg steep entry, hard chine, warped bottom to 12 degrees at transom. Am leaning toward the delta section, maybe 8'Lx2'W, thinking that the break in the keel line might bring the bow up at planing speeds, not necessarily a bad thing on a warped hull! Would this also give a cleaner wake at displacement speeds? Any thoughts, comments?
Old 09-20-2003, 07:45 PM
Rep: 494 Posts: 3,842
Could you describe the Delta section?
Old 09-20-2003, 08:09 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 409 Posts: 734
I believe you are refering to cutting off the tip of the vee bottom?
This may work. You are reducing volume aft, the boat will float a little lower aft. The low deadrise (perhaps 0?) section will act like a pad and increase lift aft, therefore the bow will come down at speed. This could be a bad thing if it changes trim too much.
good luck, Tad
Old 09-21-2003, 06:39 PM
Rep: 14 Posts: 113
Gonzo, Tad describes the delta above. I havent the foggiest clue how to design the section, but have seen it done on many deep vee hulls with quite some success. Believe these were all seat of the pants designs, no number crunching involved. Guess the danger lies in making it too large, causing the boat to ride completely up on top of it and pounding like a flat bottom. My boat is not overpowered, so I'm thinking that 8'long tapering from nothing to 2' wide at the stern should give me the prop clearance I need and possibly some planing assistance. Saw an ad for a large sportfisher where the delta section held a trimmable surface!
Human Powered Boat SolomonGrundy Boat Design 346 11-11-2009 12:01 AM
Keel section question Strand Sailboats 5 09-17-2005 07:25 PM
Offset single prop - which direction? Ben Lindenberg Propulsion 7 11-10-2004 01:53 PM
sea ray prop for planing jfc52 Propulsion 20 09-17-2004 09:09 PM
Ideal depth of prop/ surface peircing props Sonnie00 Powerboats 2 08-01-2004 08:01 PM
