Old 11-24-2004, 05:52 AM
baby baby is offline
Rep: 10 Posts: 3
project
Hi,
I am BSc naval architecture student and looking for a prefect idea that I can based my last year project on it.
I am interested in hydrodynamic and propulsion matters especially:
propeller & cavitation .
hydrofoils
If anybody has any ideas or suggestions, please let me know
I will be glad for using your experience and idea.
I thank you in advance for your help and consideration
Babak.
Old 11-28-2004, 09:45 AM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
Babak,
Here is one idea that I have proposed before, but no one has ever done any research on it. What is the best geometry for lifting strakes on a powerboat hull? Most lifting strakes run the full length of the hull, but how wide should they be, and what should be their fore/aft shape and sweep. That is, the front ends of lifting strakes are generally higher than the aft end, but how high should they be? Is lower better, or is higher better? What should be the best shape in waves and in calm water? Are they the same, or should they be different? As you can see, there is a whole host of questions regarding the design of lifting strakes, and no one ever, in my research on the topic, has ever answered these questions. We merely shape the strakes by eye, never with any scientific thought.
I hope that helps. Good luck.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 11-28-2004, 06:20 PM
nevd nevd is offline
Rep: 10 Posts: 99
spray/lifting rail optimisation
I second Eric's thoughts. As you see from my title, the project may be a little wider than Eric's recommendation as I interpret lifting rails as being partially submerged while spray rails are generally above water level at operating speed.
Optimum trim angles, lateral inclination and width for both spray & lifting rails in smooth and rough water would be very illuminating.
Unsinkable Yacht Project Herry Boat Design 35 02-09-2007 03:54 AM
Sheridan College Project Mr.Munchy Boat Design 1 09-22-2005 09:31 PM
1956 ChrisCraft Project, your opinion please... PeterH Wooden Boat Building and Restoration 13 03-20-2005 06:53 AM
Ex. Seaway Group/J&J Design/Bavaria Yachtbau Project Manager available world wide. catweaselcat Services & Employment 1 12-06-2004 11:15 AM
Project managment/Design job available? Turkey and/or multihulls preferred. catweaselcat Services & Employment 0 11-20-2004 04:06 PM
