Old 05-02-2009, 10:36 PM
toocanshan81's Avatar
toocanshan81 toocanshan81 is offline
Rep: 10 Posts: 25
problems with length?????
hey guys i have a well what i was told 1970's MFG and i bought this boat just for the motor that was hanging on the back. little did i know that the 150 hp x-long shaft evinrude was too long for the boat. anyway when i ran this boat it looked like the motor was on backwards. all this water was slamming up against the transom and it was not pretty. anyway to sum it up i did a lot of investigation and it turns out that my chances on getting a 20" shaft is next to none. even if i could find the whole lower end i would need a pro. to do the work.
what are the theory's on extending my transom about 4-5" so the cavitation plate sits where it is expected to be????
any advice and\or help is very appreciated thanks toocan
toocanshan@yahoo.com
ALL I WANTED WAS A BOAT!!!
Old 05-03-2009, 09:24 AM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
Yes, that is definitely the thing to do.
You should first determine if the present transom is in top shape. Tap on it all over with a mallet or something and listen to the sounds. If it sounds hollow to any serious extent you should probable replace the transom anyway and then just make it taller and well reinforced. If it seems to be very sound you could probably get away with putting a doubler over most of the present transom that extends high enough to make it the right height.
Old 05-03-2009, 11:32 AM
Rep: 10 Posts: 25
can someone be a little more specific on how exactly how to build on to this transom, assuming it is still solid. thanks toocan
Old 05-03-2009, 01:09 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Hi toocanshan,
Making sure the existing transom is solid is of course the first step. If it has any rot or delamination, you may as well do as Gilbert suggests and replace the transom.
If it is sound, and you want to make it higher, there are a few possibilities.
One would be to weld up a steel or aluminum filler, 5" high, to add the needed height. For a 150hp, it would have to have beefy plates welded on both the interior and exterior sides that extend down far enough to be securely bolted to the existing transom. (I did this with my runabout a few years ago when switching from a 15" to a 20" shaft. Done properly and well bedded, it's a strong and durable option.)
Another option, and one that would better preserve the look of the boat, would be to cut a 5" high wood filler piece and fibreglass it in. You'd have to sand off the gelcoat, of course, and would need enough layers of epoxy/fibreglass to make the addition stronger than the original transom.
In both cases, it may be necessary to add additional knees or bracing to the surrounding hull structure in order to properly distribute the stresses. Looking at your second photo, I'd also consider making the front of the motor well a bit higher while you're at it.
Old 05-03-2009, 02:22 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Matt's last paragraph is the most serious thing to remember. Raising the transom 5" will also raise the thrust pivot point 5" and no existing transom is likely to take that stress without some additional bracing up high. The added braces must transfer stress from the higher transom to hull stringers or other strong structure well forward of the transom.
Tom Lathrop
Old 05-03-2009, 06:03 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
When the motor is down the cavitation plate (just above the prop) should be about in line with the bottom of the hull or it will not run correctly.
Is that a slash well just in front of the motor ? Looks like it.
If you're extending the transom it better be really really strong. A 150 have some kick in it, if not done well it's going to rid you of itself very quickly, besides be vey dangerous.
I suggest you go to someone that worlks on boats and show them the setup, least get some suggestions what you can do there.
Regards
Fanie
Water ! Just gimme water !
Old 05-03-2009, 06:08 PM
Rangerspeedboat Rangerspeedboat is offline
Rep: 17 Posts: 120
Sell the motor and buy another one?
Old 05-03-2009, 07:02 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
Frankly, I would do what Ranger suggests. But, an other option is a jack plate. Rather than screwing up the transom, a jack plate bolts on and can raise and lower the transom by the push of a button.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
What shaft length ? sandy Powerboats 2 10-21-2007 12:59 PM
length of hull sidthecoolguy Boat Design 2 09-20-2007 10:38 PM
L.O.A. vs Centerline Length rdeputy Boat Design 9 11-05-2005 06:35 PM
Length Over All Danielsan Boat Design 11 02-18-2005 05:44 PM
What Length? fisherman Powerboats 2 05-16-2004 10:29 AM
