Old 10-12-2004, 07:42 PM
thecaesar thecaesar is offline
Rep: 10 Posts: 8
problem (plz help)
design apontoon to carry a wieght of 500 KN in sea water ( roh = 1030 kg/m3)
taking the thikness of steel plates 0.5cm ( roh = 7800 kg/m3)
{minimum draft 0.5m & maximum draft 1.5m }
thx
Old 10-13-2004, 10:26 AM
PNACS PNACS is offline
Naval Architect
Rep: 30 Posts: 31
Are you asking an academic problem or you really want to build one?
Old 10-13-2004, 12:07 PM
Rep: 1623 Posts: 1,483
As an academic question, this is one a primary school student should be able to solve in under a minute. As for design requirements.....
What is the minimum freeboard? maximum freeboard?
What are the maximum surge, sway, heavy, roll, pitch, and yaw? their rates? their accelerations?
What is the operational sea spectra? survival spectra?
What is the operational wind speed? survival wind speed?
Deck load?
Paint system? Biofouling rate? Service life? Docking schedule?
Questions? Questions?
Old 10-13-2004, 06:12 PM
Rep: 10 Posts: 8
thx for replying
firstly it is an academic question
& the quesion was written as professor told us
thx again
bye
Old 10-14-2004, 12:15 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
I charge only $50 per hour for homework
(Academic rates)
Steve
Old 10-14-2004, 09:15 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
Homework
I don't know where "pal" is so I can't offer to do it for a couple* beer.
Just in case you are close I will get you started by mentioning that pontoons usually have air in them (cheap) or foam (the water repellent kind).
If this doesn't help I think you should hire Steve thats not a bad rate.
Asathor
* Sailer terminology for enough beer on the table to see the project to completion. I break out in sweat just thinking about work - home or otherwise.
OMC Johnson 50 hp 2001 engine problem Guest Powerboats 8 11-05-2008 09:57 PM
Need help with new boat porpoising problem ferrazz Boat Design 27 04-15-2007 07:39 AM
Performance/Handling Problem Boa Powerboats 11 08-10-2006 07:36 PM
Water in Oil Problem ScCoghill Propulsion 3 06-05-2005 02:09 AM
Sea trials-one major problem Powerboats 6 05-10-2004 01:35 PM
