| Proa that tacks -- doesn't shunt What is wrong with a Proa that tacks -- Not a double ender - - that is a Pacific Proa on one tack and an Atlantic proa on the other tack. With the ama on the high side, water ballast could be used. Thanks in advance to replies from those more knowledgable than I. James Mills |
| Thats an non symetric catamaran. All the problems of a leward small ama, half of the advantages of a Proa. With the ama being pressed into the water on a tack, you get a heavy steering load on the ama side of the boat. Trimarans less so, because they have the weight of the windward float to help counterbalance the lee float, and the way they bounce from one side to the other in rough weather makes me think that you would need to have a really heavy small ama a long way out from the main hull. have you seen http://www.harryproa.com/ ? It might make the concept of a Proa a bit less problematic. What advantages do you foresee besides not having to build the third hull of a trimaran or a full size second hull of a catamaran? |
| Also have a look at Gary Dierkings site. He designs both shunting and tacking proas and outrigger sailing canoes.
__________________ Trev F – Amateur designer and part-time layabout. |
| A New Proa Concept? | Trevlyns | Multihulls | 9 | 10-04-2007 01:43 PM |
| the vector fin proa | fritz roth | Boat Design | 77 | 09-08-2007 02:34 AM |
| Proa steering | SeaSpark | Sailboats | 75 | 05-14-2007 11:44 AM |
| Proa question... | Anau | Multihulls | 14 | 05-13-2006 04:38 PM |
| Cruising Proa Auxiliary Power | nutty | Multihulls | 1 | 07-28-2004 06:41 PM |
