  #61
Old 03-15-2010, 12:15 AM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Originally Posted by rwatson View Post
Once again, thats where the uniquensss of the 'harryproa' design comes in. You dont have the 'small ama' problem when the accomodation is sitting away from the main hull. Capsizing at anchor speaks of a serious design problem.
Re the 'tacking versus shunting' discussion, how many times would I have loved to have been able to sit in the same shelltered spot, and simply steered onto the next tack without having to move my large ass uphill on the the other side of the windswept boat. Also, keeping the 'crew' keen to standby to get wet, cold active to assist in the rigging changes is a real downer.
Sailing on open water is such a miserable task 50% of the time, that you would have to get 40% performance increase to justify a less comfortable ride. On some sailing shots on You Tube, crew actually had to walk up really narrow bows to adjust sails on 'traditional' shaped Proas. Might have been ok back in the days of 'pressganged sailors', but not in this safety concious era.
Some good points.
I have considered the idea of an Atlantic with a single helm station. The rudder would be 1/4 the length of the boat from one end with the cockpit extending from it towards the other end of the boat.
The idea is that, on one tack, the rudder is in the stern and. on the other, it is in the bow. It would have to be able to turn a full 360 deg. to be workable, but could be a very strong spade design. It could be retractable into a trunk and replaced with an oar when beaching the boat.
The big problem I see with any kind of a proa is that, on larger sizes, the steering system is either complicated or make shift and often both. Hence my interest in a single outrigger, where the bow stays the bow and the stern remains the stern.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
  #62
Old 03-15-2010, 08:13 AM
AnalogKid AnalogKid is offline
Rep: 10 Posts: 26
I've looked at a lot of traditional proas in various museums, principally the NZ National Maritime Museum.
It seems that the long thin canoe with a single log-like outrigger was traditionally reserved for smaller craft. Some were paddled only, others sailed. Here a V shaped hull was preferable to limit leeway, since no boards or rudders were used. In these smaller craft, steering was principally by weight shift with a steering oar on standby.
For larger, inter-island and trans-oceanic craft, the two hulls are much closer in size and a substantial deck, often with a small hut built on it, was employed rather than the open structure lashed together on to the amas of the smaller proas. Again, the hulls tended to be deep V shapes but large steering oars were used rather than weight shift, I presume because the crew weight was less significant on the larger vessels.
Big or small, the idea of fore/aft symmetry rather than port/starboard symmetry is the same, and all these boats shunted rather than tacked, with no rudders, centre or lee boards.
I'll dig out some photos if I can, I think I took some of a large Fijian proa and a couple of the other bigger craft in the Pacific hall.
  #63
Old 03-15-2010, 02:11 PM
Rep: 10 Posts: 26
It seems I went straight past the big boats, I was particularly interested in this boat and took about 30 photos and a dozen or so sketches, and only a couple of shots of two other small canoes in the Pacific Hall. This boat is WHITE HERON, a 14' Kiribati proa built by the Sea Scouts of that island group.
Proa cruising sailboat design, help get this idea out of my head...-kiribati-shunting-sailing-canoe.jpg
Proa design Tcubed Multihulls 112 04-15-2009 09:15 AM
Absolutely Stupid Sailboat Racing Idea Sean Herron Open Discussion: All Things Boats & Boating 8 03-22-2008 05:29 PM
Cruising Sailboat Hullform Wolczko Sailboats 20 02-16-2008 01:39 AM
Aluminum Cruising Sailboat Construction MikeQ Metal Boat Building 7 02-14-2005 02:45 PM
Cruising Proa Auxiliary Power nutty Multihulls 1 07-28-2004 06:41 PM
