| I see what you're getting at. Something like the reverse of a submarine. Pressurizing a balloon, for example, (or a condom) does make it stiffer, but it makes it a lot weaker. Take a condom and fill it with water (not so much that it stretches), and drop it. It probably won't break, and it has only become marginally stiffer (and thats with water in it, not air). Now fill one with water until it streches a fair bit. It will only be a tiny bit more rigid, but if you drop it, it will burst. The impact loads that a boat sees are many times greater than those seen by a boat hull. With aircraft design Aircraft fuselages are not pressurized to make them stronger of more rigid. When Federal Express buys old passenger planes to use to ship cargo they de-pressurize the passenger cabin to make them stronger ( compensating for the degree of fatigue that the airframes have undergone in their lifetimes from constant pressurizing and depressurizing. What you're suggesting is definitely achievable.
__________________ JDF '"Forward, the Light Brigade!"' -Alfred Lord Tennyson |
From an engineering viewpoint it's a non-starter for rigid materials.
Small hulls rarely fail from anything if built to sensible scantlings ( exempting racing hulls). What kills them is the unplanned loads following which you will often get tensile failure of parts of the structure (as well as buckling). Ships for example often fail in tension when the deck/topsides structure prove inadequate . Also be aware that a lot of buckling in ship structures is often not a catastrophic failure in itself but leads in itself to related tensile failure. Thats why we model everything in those expensive computer packages these days. Its all horribly complex. Cheers
Nah, you're kidding me ![]() |
| Investigative FEA Finally, some numbers. Thanks MikeJohns, still curious how this FEA analysis has been done. By the way i posted a picture of the lattice mast from your gallery in the " Mast aft rig" thread Mast aft rig and followed the 2 other lattice threads in this forum. Do you have more information to share on this subject? There also is a remark about the A-mast alternative. Do you have experience with this? |
| "Hulls rarely fail in tension" OK I worded that pretty badly, the point I am trying to make is that while pressuring a rigid hull is not going to be the answer to all hull problems there are situations where it has some merit. i.e where you are trying to protect from faliure due to local buckling. Local buckling (bezier buckling) is found in structures with relatively low stiffness and thin walls. The eqn for bezier buckling of a thin walled tube is:- stress to cause buckling=.25*E*t/r where E=matl stiffness, r=radius of a tube, t=thickness of tube. If you plug a typical carbon mast dimensions into this you will see it is too stiff and thick walled to suffer from local buckling. A rotomolded catamaran hull is a different matter it uses a cheap low stiffness matl and is a relatively large diameter with a small wall thickness. e.g 0.25*1000MPa*6mm/150mm=10MPa. 10MPa is well below the normal faliure stress of the matl. Therefore unlike a carbon mast it could benifit from being Pretensioned. If you want to see how this works in practice, get a large plastic thin walled bottle of fizzy drink and take the lid off to releive the pressure, then put it back on and give the bottle a squeeze, its not vey stiff!. Next give the bottle a shake and try and squeeze it again, it is now much stiffer. This is a rigid structure made stiffer by pressure. The downside may be that while local buckling would not be a catastrophic faliure as you say (they will often spring back into shape when the load is removed), pressurising a hull may indeed put you into the realms of catasrophic faliure if you have not done your sums right. Think of the fizzy pop bottle experiment taken to the extremes. I think this is why people have stayed away from this method of hull stiffening. All the best Gareth www.fourhulls.com |
| The catapult is a catamaran with inflatable hulls, there is beam to stiffen them and a fiberglass bow section fairing http://www.catapultcats.com |
| Catapult Cat with foils Thanks for the link Granite. After some googling i found this, a Catapult Cat with foils! http://www.dcss.org/speedweek/toastrack.html |
If you want FEA tips you need to access tutorials on pressure vessels. As for lattice masts, yes lots of information, we design them; mostly for larger sailing vessels we charge $400 Australian per design . They work out very cheap to build and no heavier than the equivalent Al extrusion. You have the steel maintenance work ongoing but with modern epoxies that is minimal. A-frame spars suit modern lightweight materials but you have to allow for the compression on the mainstay trying to spread the frame so you need cross members and then the whole structure starts to get a bit too much windage. I'm not keen on aft mast designs either, too much windage aft in the bare rig so running off is dangerous in the situation that it shoulkd be safest (in a severe storm). cheers
#25
| Reputation Mike Johns, your reputation in the trial we are having has just gone up. |
#26
| Simply make it up | MikeJohns | Open Discussion: All Things Boats & Boating | 4 | 10-01-2005 04:26 PM |
| Who can make me a cost effective mold for a 11ft polyethylene hull? | sir-speed | Boatbuilding | 4 | 06-02-2005 09:26 AM |
| How to make repairs to a gelcoat hull | Guest | Fiberglass and Composite Boat Building | 0 | 01-10-2005 05:32 AM |
| How to make a name for yourself ! | Tim_Hastie | Boat Design | 28 | 06-06-2004 12:14 AM |
| How do you make a deck. | Guest | Boatbuilding | 1 | 09-04-2003 08:58 PM |
