Old 04-02-2008, 10:09 PM
jamesflett jamesflett is offline
Mech Engineer
Rep: 32 Posts: 40
Pre-planing Methods?
I am conducting some scaled tank testing (model size=1.050m) as part of a university engineering project for pre-planing and planing conditions.
I have written a program using Savitsky for planing based on equations from his 1964 paper.
The project focuses on planing ability and hence requires analysis for pre-planing. The ultimate determinant from the project is to predict changes in lift and drag with respect to speed in sub planing conditions leading into full planing. What is the most appropriate method is associated with pre-planing speeds for drag and lift forces. I have heard of the Savitsky pre planing method but have to literature for it. Is it any different to his 1964 paper?
If it was possible to have any guidance or literature associated with this, it would be much appreciated
Cheers
James
Old 04-08-2008, 12:31 AM
brissyben brissyben is offline
Rep: 10 Posts: 10
Hi
I am doing a report on savitskys 1964 paper, how ever the copy i have is missing a few figures and the text is hard to read,
do you have a pdf copy of this paper or know where i can get one?
Sorry i am not much help to your question but any help you could give me would be great.
Thanks
Ben
Old 04-08-2008, 02:40 AM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 253 Posts: 526
Daniel Savitsky Textbook
Old 04-08-2008, 03:13 AM
Rep: 10 Posts: 10
Thanks i will try and contact him.
Ben
Old 04-14-2008, 08:12 PM
Mech Engineer
Rep: 32 Posts: 40
Ward Brown and Savitsky paper
Does anyone have access to this paper at all? as a pdf?
Daniel Savitsky and P. Ward Brown, "Procedures for Hydrodynamic Evaluation of Planing Hulls in Smooth and Rough Water," Marine Technology, October 1976 Issue, SNAME, Paramus, NJ.
James
Old 04-14-2008, 08:40 PM
Jimboat's Avatar
Jimboat Jimboat is offline
Rep: 113 Posts: 189
"Procedures for Hydrodynamic Evaluation of Planing Hulls in Smooth and Rough Water" is a SNAME published paper. You can purchase the paper directly from SNAME.
Mech Engineer
Rep: 32 Posts: 40
Will do. Thanks
Old 04-15-2008, 07:49 PM
Rep: 10 Posts: 10
I have a PDF version of Savitsky and Brown "Procedures for Hydrodynamic Evaluation of Planing Hulls in Smooth and Rough Water"
If you still need a copy let me know and i will email it to you. I also have access to a varitey of other papers on similar topics, if you need any others.
Ben
Old 04-17-2008, 03:08 AM
Rep: 10 Posts: 10
This may seem like a stupid question, but does Savitskys methods in his 1964 paper require that we use imperial or metric value's? It seems that i have only been able to get reasonable answers when i use Imperial.
I thought the coefficients in some of the equations may have been derived using imperial values.
any help would be great
Ben
Pre-Project Questions quartzeye Boatbuilding 10 07-26-2007 08:50 AM
new fiberglass hull from pre-existing plastic one bobbyzahn Fiberglass and Composite Boat Building 3 05-19-2006 04:06 PM
Pre-Master Course in Geneva, Switzerland. ellen Education 0 05-24-2005 05:53 AM
Pre-Master Program in Switzerland. stuvn Education 1 04-01-2005 05:22 PM
Pre Release brad123 Fiberglass and Composite Boat Building 1 04-17-2004 10:03 AM
