| Powerboat Turning / Chine Design Id like to hear thoughts on this topic. Hard chine and slippage VS soft chine (round) bildge and digging / rolling into turn on planing hulls / powerboats. |
| Id also like to hear how a chine spray chine works when located aft of the beam. |
| I am not quite sure about what is being asked in these questions........ but obviously a hard chine is more efficient as regards lift and wetted area, all else being equal. I have seen planing hulls, outboard powered, that heeled pretty dramatically in turns because of the lack of a hard chine.Wide spray chines aft will further reduce heel in turns, and also flatten the angle of attack underway, because they create greater lift, at a point well to the rear, but can harden the ride, in some conditions.. For deadrise at the transom more than about 12 degrees, digging in and tripping when pushed hard in turns should not be an issue, there will be enough heel to avoid problems. |
| Your question can't have a significant answer.There are many more factors than just hard and soft chine.
__________________ Gonzo |
| Chine and strake design | meren | Powerboats | 45 | 06-01-2010 10:48 PM |
| chine design software | northerncat | Software | 4 | 05-12-2007 04:41 AM |
| A round chine design?? | xalexc | Sailboats | 15 | 05-09-2006 05:46 AM |
| double chine hull design | azulkhai | Boat Design | 5 | 07-22-2003 06:28 AM |
| Chine Design | Archive | Powerboats | 3 | 08-29-2001 04:29 PM |
