| Powerboat shaped canoe body vs Mac Gregor vs Sailing Hi, I've been reading boatdesign forum for some time, but never felt a need to write about any problems. But now I'm little confused. I see boats like Mac Gregor or Odin, and they're bottoms seems to be good for planning, but software and theoretical calculations says slightly different. What I've found and dont know if it's correct, is that Mac gregor - shaped bottom is about 15-20% less efficient than bottom of typical sailing yacht, and about 30-35% less than powerboat shaped bottom. Assuming the same LWL, BWL, Disp and velocity around 25kts. Any thoughts? |
| When you say "what i have found" - is that your calcs? As an ex owner of a MacGregor I would have said 10% off the hull speed sailing. I never got to compare 26ft power boats with 50hp motors, but 18 knots seemed pretty good for the weight and the mast and rigging. I am in the design stages of a similar boat, and i told the designer to ramp up the powerboat hull efficiency, at the expense of sailing. My logic is that a percent of 6-10 knots is hardly worth bothering about, but 10% of 20 knots is more noticable. I wonder how the really flat bottom boats like Norwalk island sharpies and Bolger designs work out? |
| To my eye, the bottom shape of MacGregor 26 is more or less optimal for speeds 10-20 knots. At sailing speeds there is lot of viscous pressure resistance caused by the transom separation, approx 15-20% more total resistance at 5 knots compared to optimized sailboat form. The numbers are from semiplaning test project, which end up very similar hull shape. |
| Well Yes, I have counted it one more time, there is realy less resistance on the MC hull at 10+ knots. I've just used wrong methode. So another question. What do You think about designing hull for velocities exeeding 25 knots? I dont know much about yacht bechaviour at this speed. Is it still safe? |
| I know 20 knots under power is great in smooth seas, but with enough wind to sail a boat at 20+ knots you are usually going to get very rough seas as well. Powering at 12+ knots through very rough seas is veeeery uncomfortable in a monohull. I would prefer something long and narrow in heavy seas like a tri or cat, but rolling and tumbling in 25+ knots in a monohull is hell, as any sydney to hobart yachtie will tell you. |
| powered body board | sean_manning | Jet Drives | 2 | 04-08-2008 11:19 PM |
| better body plan | CapKos | Boat Design | 4 | 05-07-2007 04:34 AM |
| how do you make your own fiberglass body | huntermike32 | Fiberglass and Composite Boat Building | 12 | 11-02-2005 06:43 PM |
| glassing over body filler? | LKJR | Fiberglass and Composite Boat Building | 4 | 05-27-2005 03:47 PM |
| Affixing full keel to canoe body | RDB | Boat Design | 0 | 05-17-2004 06:58 PM |
