Old 02-22-2005, 01:30 AM
BayouDude BayouDude is offline
Rep: 10 Posts: 19
Power Trimaran
I am taking a course at the University of New Orleans and am going to design a power trimaran. I would like to do something about 80-100 foot with a 20-30ft beam, a range of 1000 miles and a cruising speed of 20kts. I was thinking the vessel would be used for a live aboard dive boat or possibly a yacht. I was intrigued by the trimaran hull and was wondering if anyone had any suggestions? Any input would be appreciated.
Old 02-22-2005, 03:30 AM
fcfc fcfc is offline
Rep: 333 Posts: 680
You should look at Nigel Irens designs.
Old 02-22-2005, 09:11 AM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
What might be your motivation to choose for the power tri concept? Any mono would feed with ease your bill of requirements. The power tri, in its true concept, is just to achieve speeds normally unobtainable by monohulls. If you are looking for the wide-bodied designs you better go for the cat design.
I play a bit around with tri-designs, actually winged monohulls, to go fast, stable and with a minimum of draft that allows you to enter shallow waters. Beachable too.
Old 02-22-2005, 10:12 AM
doesitfloat doesitfloat is offline
Rep: 10 Posts: 19
I did some work a few years ago with a concerp of a tri Patrol boat. There was a large gain in deck work area however the seakeeping limited it's operation. If it's a fair weather fun boat probably work out just fine.
Old 02-22-2005, 02:05 PM
Rep: 10 Posts: 19
Thanks for the input. I have just taken a look at some of Nigel Irens designs and they are impressive. I have decided on the trimaran because the class focuses on cats, tris and surface effect ships. Most of my experience is in tugs and offshore supply vessels so this high speed stuff is somewhat new. I would prefer to do something other than a monohull even though the benefits offered by a trimaran for this size and speed may not be exceptional.
Old 02-23-2005, 11:34 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 997 Posts: 2,298
I own a small hovercraft and have notice that Sevtec hovercraft kind of function like a catamaran- but not exactly.
This got me to thinking if there was any tri-pontoon type surface effect ships.
I know that the solid sidewall wall cushion vehicles are a form of non-displacement cat, in a gray area way.
If the hovercraft bag side skirt is made to be of such high pressure that it acts as a inflatable pontoon - or RIB (rigid inflatable boat), then it would act like one, right?
The wave impact on a RIB is turned into mechanical energy by the air-spring effect which then allows for higher speeds, right? So even a non-displacement hovercraft should be able to deflect more of the wave energy impact, or so it follows to think so.
What would a tri-pontoon type surface effect ship really look like?
Actually I have drawings and built a non-working model. Just trying for a little feed back before I post it or do more work on it.
If this concept has been explored or dicsucssed before, please suggest or provide a link. Cheers all.
Note - cool link:
http://www.nigelirens.demon.co.uk/index2.htm
Old 02-28-2005, 07:23 PM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
Drawings and ideas.
Throw on some drawings please!
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Old 03-01-2005, 06:04 AM
Rep: 700 Posts: 3,208
A liberal is
forward thinking
and the only
way to be...
politically
To not be a liberal when your 18 means you have no heart,
to not be consirtive when your 40 means you have NO head!!
Old frog saying,
FAST FRED
Old 03-01-2005, 02:52 PM
Caveat Emptor........
Old 03-01-2005, 05:25 PM
boby boy boby boy is offline
owner of cla boat design
Rep: 10 Posts: 32
I believe a trimaran is a wonderfull choice, a multi hull boat was my first creation. just some advise fom a previouse design of mine: if you are gouing to have a center board instead of a fixed keel it is very conveniant to run it through a table below deck. this way it gives the table added suport and keeps it out of your way
Old 03-16-2005, 09:19 PM
boatgm boatgm is offline
Rep: 16 Posts: 24
i just started building a power tri will keep you'll updated
Old 05-11-2005, 10:03 AM
brian eiland's Avatar
brian eiland brian eiland is online now
Rep: 1503 Posts: 2,648
Tri Hull power yacht
I assume you are familar with this recently launched tri-hull vessel http://www.yachtforums.com/forums/sh...6&postcount=26
RunningTideYachts.com
Distinctive Expedition Yachts
Old 05-11-2005, 10:32 AM
kach22i's Avatar
Architect
From brian eiland's second link:
http://www.naval-technology.com/projects/trimaran/
ADVANTAGES OF TRIMARAN DESIGN
The advantages of a trimaran hullform over conventional mono-hulls are thought to be: reduced costs, reduced signature, significantly less drag increased speed, increased length, giving greater stability, and more room for the upper deck, which could be used for the flight deck as well as hangars for helicopters and extra armaments.
Reduced cost?
I'm not sure building three hulls is cheaper than one larger hull. However I agree with the rest of it for the most part.
What happends when a surface to surface radar beam hits the main hull and bounces back and forth inside/against of the smaller outboard hull? Does it get trapped or sent back to the sender giving away the location?
Old 05-11-2005, 05:38 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Radar signature depends very much on the shape and material of that hull. 90-degree angles are very good radar reflectors; stealth aircraft usually use a lot of 48-degree angles to minimize signature. Metals generally reflect more than composites. The shape of a boat is so complex that it's hard to predict radar signature without an actual test range. Having said that, if you suspect your vessel's radar signature is small (often the case with thin composite-hulled boats) it is prudent to hoist a reflector.
Old 05-12-2005, 09:56 AM
kach22i's Avatar
Architect
Reduced cost......could of meant "reduced operating cost".
That is to say for faster speeds it consumes less fuel - I guess.
I'm thinking because the water surface is a large reflective plane, things could be different for boats than airplanes.
I've noticed all the current and future watercraft designs are stealth, patrol boats, Corvettes, Destroyers and so forth are all clean deck flat plane designs - not much more than 10 degrees (in lieu of 48 degrees).
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
electric propulsion Lew Morris Propulsion 21 03-21-2005 01:08 AM
Article on converting 43-footer to diesel-electric propulsion lockhughes Open Discussion: All Things Boats & Boating 13 09-01-2004 08:14 PM
