Sounds interesting... Cheers, Dave |
| On the power tris: 30ft beam on a 100ft tri does sound rather narrow. I've seen monohulls with that length-beam ratio. The interactions of the wakes of the central and outer hulls would probably be a pretty important thing to watch for. I don't think it would be an easy analysis to do. On the radar stuff: (perhaps we should start a new thread for this?...) The slight angles you see on stealth ships work well at sea. On an aircraft, where radio waves can propagate in all directions, the 48-degree angle is most effective at reflecting the beam in a different direction than it came. On a boat, the shallow angles you see on stealth corvettes reflect marine radar signals so they do not return in the direction they came from; radar from aircraft is reflected into the ocean where the waves cannot propagate. It is a matter of intended purpose and surrounding media that dictates the design of a stealth vehicle.
A new thread? Sure, but I have to go right now. Cheers George/kach22i. |
| depends on the angle they hit- like all electromagnetic radiation, radar waves are reflected at some angles and not at others. the way light reflects off of waves is a perfect example; it's the same type of radiation as your radar just with a much higher frequency.
| "On the power tris: 30ft beam on a 100ft tri does sound rather narrow" The power tri would not have the usual loading of mast and sail , so the amas would merly be "Training Wheels ". The main hull would have an L/B ratio of 8-1 up to 15-1 . so an overal beam of 30 would be quite generous , and only needed for a small % of the hull legnth. With no need for a help pad the vessel might even be narrower overall than 30ft. With many travel lifts limited to 20 ft , with relativly short far aft amas , a small yard should be able to service her. FAST FRED |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 07:34 PM | |
| Option One - how big | Willallison | Option One | 43 | 12-20-2005 05:44 AM |
| electric propulsion | Lew Morris | Propulsion | 21 | 03-21-2005 12:08 AM |
| Article on converting 43-footer to diesel-electric propulsion | lockhughes | Open Discussion: All Things Boats & Boating | 13 | 09-01-2004 07:14 PM |
