Old 04-17-2006, 12:46 PM
cjs cjs is offline
formula18
Rep: 2 Posts: 15
power predictions method
Hallo
I will design an approximately 70 x 30 meters roro catamaran with wawe piercing hulls. Do You have any ideas if there is any appropriate resistance prediction methodes (semi empirical) for that kind of vessels. I guess that Holtrop and Mennens method not will do the work
brgds
C-J
Old 04-18-2006, 09:01 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
No, Holtrop and Mennon won't go anywhere near a catamaran, especially a wave piercer. AF Molland's work on Catamarans may be of more use, but I think fairly extensive tank testing would be highly advisable.
Tank testing will also give a good insight into the sea-keeping abilities, and (with the right model) sea-keeping in flooded conditions.
These vessels are quite hard to design, approach the problem carefully,
Tim B.
Old 04-18-2006, 09:36 AM
french44 french44 is offline
Rep: 63 Posts: 23
test with michlet program i test it on big vessel (with bulb and trim wedge)and i have very good results on bare hull i compare with towing tank test and it'very good for 80% of hulls (include pods design hull)
french 44
Old 04-18-2006, 09:41 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Michelet is a good option for resistance prediction in slim displacement hulls; it will also calculate interference drag in a multihull. Your individual hulls must have length/beam ratios of 6 or more to get good results from it, and should operate at a subcritical Froude number (full displacement hulls work best). It will not do any stability or trim calculations for you, but will give pretty good resistance and power curves. I agree with Tim that if you intend to actually build this vessel, you will need to do a lot of tank testing; I would include tank testing with appropriately scaled waves as well.
Old 04-26-2006, 09:25 PM
cuongshipdesign cuongshipdesign is offline
Rep: 10 Posts: 3
hey, I may help you. I now own the Auto power software. But you must provide me more characteristic of the hull. The best way is to give me your lines plan.
My email is cuongshipdesign@yahoo.com
Best regard
Old 04-27-2006, 03:44 AM
cjs cjs is offline
formula18
Rep: 2 Posts: 15
That wolud be very nice, I email You the linedrawings in a couple of days.
Which file format do You want?
Old 04-27-2006, 04:46 AM
PNACS PNACS is offline
Naval Architect
Rep: 30 Posts: 31
Its pity that, we naval Architects are lagging behind latest scientific advancement. We are still dependent on empirical relations, statistical data from series of model tests in 1970s-80s. CFD methods are still in their transformation state to produce reliable results & common usage!
New Ultralight Boatbuilding Method Antonio Bordeu Materials 17 03-15-2008 07:16 AM
The best fairing method? Capt. Chris Fiberglass and Composite Boat Building 6 10-07-2005 05:47 PM
which construction method? mjpetersen68 Boatbuilding 12 09-26-2005 03:48 PM
Help choosing building method fede Boat Design 38 02-20-2005 08:20 AM
Help with One-Off Method LBS Fiberglass and Composite Boat Building 6 02-11-2005 10:12 AM
