Old 01-28-2009, 02:28 AM
640 blazer 640 blazer is offline
Rep: 10 Posts: 7
porpoising hull
If a 21ft planning hull is balanced corectly and the motor trimed correctly but has a tendancy to porpoise in any given situation (if thats how you spell it )whats going on with the hull design , is it concave or convex and would trim tabs help ?
Old 01-28-2009, 03:02 AM
Rep: 2891 Posts: 8,796
How do you know your 21'er is trimmed properly? 90% of the time, small boat trim (engine and weight distribution) will sort out proposing. If it's a manufactured boat, it's very likely not a design issue. If it's a home made boat, then Lord knows what you've got going on.
Old 01-28-2009, 03:24 AM
Rep: 10 Posts: 7
Lordy knows its a manufactured hull ! it runs fine I was just interested to know what the reason for a senario like this would be . My boat hates being tail heavy but when its wt and ballance is the best for planning it seems nose heavy when just bobbing around in a semi rough sea .
Old 01-28-2009, 04:14 AM
Previous Member
Rep: 0 Posts: 0
This site will give you some insight into tendency to porpoise:
http://illustrations.marin.ntnu.no/h...ing/index.html
Enter your boat data and check tolerance to weight distribution by adjusting the lcg. You can also alter the motor thrust line if you have the ability to adjust this.
Boats become more prone as speed increases.
Rick W
Old 01-29-2009, 02:36 PM
PortTacker PortTacker is offline
Rep: 25 Posts: 77
Look closely at the bottom of the hull, especially the aft third.
Is there concavity or convexity? If there is either, it will probably porpoise.
Also, could you be trying to outperform its design? (over powering?)
We put a 55hp jet (from a PWC) in one of those 8' mini boats once - it wouldn't go any faster, it just porpoised horribly. We added a trimmable nozzle which helped a little - ended up with huge trim tabs, stopped the porpoising but netted very little extra speed because of the drag. It was simply not a design that could support the speed, and it preferred the weight of the motor off the transom, not inside the stern. (We got to about 30mph.)
The shape/design of the hull makes a difference. Lots of variables.
Old 01-29-2009, 03:31 PM
Previous Member
Rep: 0 Posts: 0
Attached shows what Savitsky predicts for my guesstimate of data matching your mini boat.
Rick W
Old 01-29-2009, 04:01 PM
Nick F Nick F is offline
Rep: 10 Posts: 19
Rick W
Thats a great site Rick
This may be a silly question but how do you read the out put on the graph? how dose one tell if porposing is going to be a problem?
Nick
Old 01-29-2009, 04:51 PM
Previous Member
Rep: 0 Posts: 0
Nick
The red line gives the lift relationship and trim angle for the particular hull being examined. If this line is above the limit line for the deadrise of the hull shown in the various green lines then the hull will have propensity to porpoise.
There are two common solutions to porpoising. One is to shift weight forward. This increases the lcg. You can alter the lcg and see what it does. With a small boat the pilot and any passengers weight will have a large impact on the location of the lcg.
The other is to fit trim tabs. This reduces the trim angle and you will see from the plot this is stabilising as you get the same lift at lower trim angles.
With outboards and some jets you can alter the thrust line as well and this can be used to reduce tendency to porpoise but Savitsky indicates it has little affect.
Rick W
Hull Design and Porpoising Houndie Boat Design 18 01-09-2008 07:10 PM
porpoising saeedeh Stability 1 10-29-2007 05:22 PM
Hydrasport Porpoising CROW Powerboats 14 09-17-2007 11:01 PM
Understanding Porpoising CET Boat Design 35 12-05-2005 08:59 AM
Porpoising Boat Design 4 12-10-2002 05:56 PM
