  #121
Old 10-05-2010, 07:31 PM
WestVanHan's Avatar
WestVanHan WestVanHan is offline
Rep: 413 Posts: 657
That Pazapa reminds me of a Davidson Chugger....there was a guy going up and down the BC Coast with one a few years ago.
For those who don't know they were based on lifeboat hulls,don't know if many are outside of BC.
He had plans to go to Hawaii.
Skip the first 3 minutes...and beware country music
http://www.youtube.com/watch?v=M0Q1u_n2YF4
And though sails are involved several 25' Heavenly Twins catamarans have circumnavigated (one around Cape Horn),many Atlantic crossings, and a few have done the N. America to Australia trip
http://www.2hulls.com/gallery/Model/...Catamaran.html
Poor man’s passagemaker-030815chuggertop.jpg  Poor man’s passagemaker-davidsonchuggerpender.jpg  Poor man’s passagemaker-1282419151_1654_view_800.jpg
  #122
Old 10-05-2010, 08:21 PM
u4ea32's Avatar
u4ea32 u4ea32 is offline
Rep: 175 Posts: 378
Originally Posted by Tad View Post
In 1985 Irishman Enda O'Coineen crossed the Atlantic in a 17.5' RBI powered by a 55HP Suzuiki outboard. That same year American Al Grover and his son crossed in a stock 26' Groverbuilt skiff with twin 65HP Evinrude outboards.
In 2002 the Spirit of Cardiff, a 30' RBI, went around the world in less than 80 days underway.
Back in about the late 1970's a 11.9m (39') aluminum motoryacht designed by Dick Koopmans circumnavigated.........
So the minimum is whatever you happen to have.....
Totally agree.
David Smyth
  #123
Old 10-05-2010, 10:04 PM
srimes srimes is offline
Rep: 186 Posts: 226
That's interesting, especially the Spirit of Cardiff. What to y'all think of planing offshore cruisers? I thought they couldn't carry enough fuel and still get on plane, but I guess that isn't the case?
  #124
Old 10-05-2010, 11:32 PM
WestVanHan's Avatar
Rep: 413 Posts: 657
This crossed the Atlantic...
http://www.mayrik.com/HomeEnglP214.htm
  #125
Old 10-06-2010, 04:25 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
....so did an 18 foot Hobie, but so what.......
....poor mans passagemaker or poor man ready to meet his maker?
  #126
Old 10-06-2010, 05:11 AM
apex1
Originally Posted by u4ea32 View Post
Clearly, one can build such a boat cheaply. One can also emulate the boat by simply taking an existing fiberglass sailboat and tossing the rig into a dumpster. Get rid of some or all of the ballast to make room for the half ton or so of fuel. Plenty of sailboats in the 30 to 40 foot range power near hull speed at fuel burn rates approaching 10 nautical miles per gallon.
This ain't rocket science. Any displacement performance model shows this to be easily obtainable.
True, it aint simple rocket science, it s much more complicated.
Clearly, one can NOT just remove the rig from a sailing boat and assume to have a seaworthy boat anylonger. If your claims about your experience would be true, you would know that!
I cannot believe this statement, Apex1. I cannot believe anyone can "circumnavigate or sail almost year round" and not know MANY people who are doing it on very low budgets. You are simply not credible ON THIS POINT.
You do seem to make sense most of the time, but here you are simply spouting nonsense.
Just as the former compliment:
returned unused.
I do not believe one single of your statements, being all completely wrong or even dangerous!
And you should not manipulate quotes! I said: "circumnavigated several times and sail almost year round".........not or
Thanks Tad and WestVan,
who would not know of similar examples. But do we call them "passagemakers" ? Capable boats for extended cruising? Really?
Regards
Richard
  #127
Old 10-06-2010, 06:24 AM
Rep: 756 Posts: 3,328
I have a neighbor in Fl that did just that.With a "hurricane boat".
He did keep the mizzen , as a main mast , to use as a radar, antenna mast and to check the roll.
A good portion of the iron keel was removed , and a new 80HP John Deere installed.
No he doesn't run offshore voyages , but the great Loop was a snap , as is trips to Maine for the cooler summers.
The only improvement I would make would be a geared tabernakle (as used to raise flag poles) to allow passing under the many opening 18-24ft bridges.
Perhaps not a Cape Horn vessel, but a really practical way to get a comfortable displacement , cheap to run, cruiser.
FF
  #128
Old 10-06-2010, 02:53 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
I don't think that will make any kind of "passagemaker" though it may make a powerboat.
Even at 10mpg, 2400 miles plus a 20% reserve is 300 usg, which is about a ton, or 40 cubic feet of fuel tank. That's a huge hollow keel for which the boat's structure was not designed, or a tank on the main cabin sole that's 6.5' by 5' by 15" high. It pretty much makes useless the interior of a standard production sailboat. Personally I'd want at least 400 gallons, plus a shortened rig, plus some ballast, plus a roll-reduction system (key to making a real passagemaker).
We don't see production sailboats made into powered passagemakers for two reasons.....1) They work just fine as sailing passagemakers as they are......and 2) It doesn't work......
  #129
Old 10-06-2010, 07:57 PM
WestVanHan's Avatar
Rep: 413 Posts: 657
Don't put words in my mouth.
It's something interesting...if you don't find it interesting or if what I post offends you-ignore it or don't reply.
  #130
Old 10-06-2010, 08:03 PM
Rep: 501 Posts: 1,767
True, but a custom made sailboat or perhaps a certain sailboat could be converted. One might fine one in a steel or aluminum boat that has structure to hold weight. But like you said why would anyone convert to power only, unless they just couldn't sail.
  #131
Old 10-07-2010, 12:32 PM
u4ea32's Avatar
Rep: 175 Posts: 378
My point was not that "buy a sailboat and dump the rig" was the best way to go, but simply as an existence proof that:
1) Fuel efficiency of well over 5 nmpg, even as high as 10 nmpg, is VERY easy to obtain if one uses a sailboat hull form, displacement speeds, and modest diesel power. One still gets adequate accommodation and structure while still being much more seaworthy that most anything in "Voyaging Under Power" by Beebe.
2) Very, very few dollars could be expended to achieve this, IF one wanted to live with the inconveniences present in all sailboats, AND one was not embarrassed to power around in a sailboat without a mast.
Tad, I am sure that 400 gallons of fuel in tanks (2400 lbs) is substantially less structural load that lead hanging below. If the boat can support a keel and rig lads, it can handle fuel tanks. Might be a pain to fit them in, but one can get rid of the keel and put some there, no more need for sails, ... Does not seem a difficult issue.
Why are we talking about a "poor man's passagemaker" anyway? Its to explore ideas to do things on the cheap. This is not one of the "perfect passagemaker" threads. Its different, we are brainstorming different ways of doing things. Instead of "perfect" being the goal, "cheap" is the goal.
In my mind, getting rid of the rigging saves a LOT of money over any reasonable period of time. So keeping it a sailboat blows too many of the constraints on cost, safety, and area of operations.
Remember that Colin Archer lifeboats and sailboats had very similar ballasted displacement full keel hull forms.
David Smyth
  #132
Old 10-07-2010, 12:35 PM
u4ea32's Avatar
Rep: 175 Posts: 378
FF
Even to tackle Cape Horn, a sailboat without a rig is probably far safer than virtually any production powerboat.
David Smyth
  #133
Old 10-07-2010, 12:46 PM
u4ea32's Avatar
Rep: 175 Posts: 378
All men, rich and poor, eventually die.
I think we want to consider ideas that maintain safety.
I think we can agree that life boats carried by commercial ships are both very safe and much, much smaller than the ship! And sea buoys are pretty short LOA too. Hence, size by itself does not directly correlate to safety.
Cost also is no guarantee of safety. Often, cost goes into unneeded complexity that can increase risk. Also, cost can lead the owner to make very poor decisions of trying to protect the boat, where it would have been far safer to leave the boat and fly to safety.
And finally, safety is far, far more correlated to the crew than the boat. More time using the boat, and less time working to pay for the boat, may well be a far safer strategy.
David Smyth
  #134
Old 10-07-2010, 02:05 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Avarege modern sailboat is not in a passagemaker even when that term is understood as widely as possible. It's just don't have displacement enought to be one. Surely they cross oceans but they do it with severe shortcomings.. counting every drop of water and fuel used.. filling more from places where you can count having them both with same fill, in the same tank.
Throwing the keel and rig of would create a poor power boat from a poor sail boat ("poor" meaning poor passagemaker)
You need some more displacement
Dave Gerr put this in a form of a formula in the book "the Nature of Boats" page 100..
So lets assume 5000nm range and only 2 crew. So.. the crew 150kg, personal "stuff" min 2x180kg, food and water 2x40days x 6.6kg, total around 1050kg.. It's means you need atleast a 10t boat..
  #135
Old 10-08-2010, 06:13 AM
"It's means you need at least a 10t boat."
At our FL dock sits a Beneteau First 32 , (1982) that came over on her own bottom.
17G fuel , 17 water , augmented with a 50gallon water bladder under a bunk for the trip.
The boat weighs about 8000lbs .
Perhaps too much motion and lack of comfort for geezers , but many similar $10,000 boats are out doing the world , with ease.
Passagemakers? Would seem so.
FF
poor performance dbsupra Inboards 1 06-16-2009 01:26 PM
Will This Boat Float: well, poor ratrace2 Fiberglass and Composite Boat Building 4 05-05-2008 09:41 PM
Poor man raft. help! cheapSauace$20 Boat Design 2 01-04-2008 09:47 PM
Alas poor..... Bergalia Open Discussion: All Things Boats & Boating 18 05-07-2007 03:56 PM
Passagemaker taniwha Powerboats 9 03-18-2007 07:33 AM
