Old 09-23-2010, 11:37 AM
ddrdan ddrdan is offline
Rep: 37 Posts: 66
Pontoon Questions
1. Two pontoons won't hold the load I need, based on the length and width restrictions on the vessel. I'm adding a center pontoon (tritoon), shorter in length of the others. What is the optimum position of the center pontoon. Even at transom? Forward? Trailing? I like the trailing option as it fits the motor design best.
2. The pontoons are 24"x24" 1/2 ply with 2oz chopped strand & resin. The stern and bow interior compartments will be glassed also. Ignoring deck loading for now, what would your average max spacing be on the bulkheads? Typical type construction in pic below.
Old 09-23-2010, 12:01 PM
Rep: 1758 Posts: 1,561
If you don't have enough buoyancy, then the 3rd pontoon has to be placed so that the center of buoyancy of all 3 hulls is directly under the center of gravity for it to be of optimum use.
Just because the boat is heavy, doesn't mean that all you need to do is add buoyancy, that buoyancy must be in the proper place in relation to the CG. Otherwise the boat can take unfavorable pitch angles which may cause the craft to become unstable.
If you have an existing measurement of the CG and CB, then you could design a 3rd hull for optimum buoyancy, and shape/location for powering. If you have already built a 3rd hull, then you need to place it in the proper loaction for CG/CB consideration and take whatever performance hit there is. If the boat is still building and you are looking for performance and will ballast to level trim, then the better location of the center hull is forward of the two outer hulls a distance dependent on spacing and speed. Optimally, the center hull should be longer than the two outer hulls.
As for bulkhead spacing, that is dependent on load and length.
Old 09-23-2010, 02:53 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
A good spacing between bulkheads would be about 24"-30" with 1/2" plywood. They could have a large hole in them except where making watertight compartments.
Old 09-23-2010, 04:22 PM
Rep: 37 Posts: 66
Thank you for the suggestions.
I'm at a stage in the design where weights can be moved to accommodate CG & CB. Speed will be 15 knots max.
I guess longer it is, and forward it goes.
My initial design was to have the center hull sit 4" deeper. My structural deck supports are galv. steel and integrated into the outer hulls, not on top. Any disadvantages or advantages in that design? I'll never power the vessel enough to get it up on plane.
Old 09-23-2010, 04:25 PM
Rep: 37 Posts: 66
Thanks,
That close huh? Puts a damper on my placing long water tanks in the hulls.
Old 09-23-2010, 05:36 PM
Rep: 3125 Posts: 9,398
Depending on the type of plywood, I wouldn't go larger then 24" on center for partitions. I would also fillet each all the way around too, to prevent point loading.
Old 09-23-2010, 09:10 PM
Rep: 37 Posts: 66
I really appreciate the input. I hope I'm not ruining my welcome in more questions?
Would increasing the bottom and partitions to 3/4" give me any increase in partition spacing? And if the partitions are 3/4" ply with 1x2 edge all around would I be able to remove a portion of the 3/4" web for pass thru's in the hull compartments?
Old 09-23-2010, 11:55 PM
You're going to find it difficult to get answers if you don't ask questions Ddrdan. I'm not sure of the loading you anticipate but 3/4" plywood will be impossible to bend into the entry shape. Use the plywood thickness you need for the loads you expect, going thicker is just a burden the boat has to bare. Don't increase the partition spacing. Plywood doesn't like widely spaced bulkheads in narrow hull shapes like this. Design them as ring frames, rather then full partitions. This will permit some storage options, save a considerable amount of weight and offer good ventilation. I'd use at least a 4" web depth for the ring frames, with a 6" bottom web for slamming loads. This will provide about a 16" square hole in the partitions to pass things through. The inside corners of the cutout should have a healthy radius, say 6" diameter on the top two and 8" on the bottom.
Old 10-04-2010, 06:29 PM
Rep: 37 Posts: 66
I've tried everything I've learned in here .... but ....... I can't live with 24" partition spacing!!!!
I have a water tank, a cooler, and a livewell that won't squeeze thru an open partition web and they need larger spaces between partitions.
I will never operate this vessel in seas over 1 to 2' or speeds higher than 15 knots. Here's what I came up with. I doubled the partitions at my deck cross members and added stringers @ 6" o.c.. Hull is 18'-6 o'all. I'll glass the stringers.
The 40" space will have a 2" rigid foam fiberglassed in place cooler. That should add some strength to that largest space.
I know I'm adding undue weight to accommodate the spacing.
Your input, as usual, is greatly appreciated!
Olds 455 questions upon questions... pdswerld Gas Engines 26 07-07-2010 09:36 AM
pontoon houseboat questions doingitmyway Boat Design 5 03-04-2008 08:07 PM
pontoon thecaesar Boat Design 0 10-12-2004 01:40 PM
pontoon Fred Boatbuilding 1 06-02-2004 03:09 PM
Buying Pontoon Powerboats 3 02-15-2004 09:08 PM
