  #31
Old 08-20-2011, 09:35 AM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
There was a boat, Transporter or something like that which used a jet ski locked into place. The bow of the ski was locked into place, otherwise it had a tendency to dive under the boat during acceleration. I rode on one about ten years ago and the boat was about 14 or 15 feet and you sat on the jet ski to drive it. You might find the best position for your ski and build the female section in the form of the ski, that is how the other boats were made and at least pin the boat at three points with some arrangement.....good idea and good luck with it!
  #32
Old 08-20-2011, 09:59 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Post # 3 in this thread provides a link to what you are probably describing, the "shuttle craft.
I'm sure it isn't perfect, I'm sure Eric will tweak it some more, but as far as projects I have seen discussed and documented here, this project is an A+.
Steve
  #33
Old 08-22-2011, 06:16 AM
ericrunner ericrunner is offline
Rep: -24 Posts: 35
honestly the pon-doo works great but it needs a big jet ski so its not for every one . So i came up with a plan B
Pon-Doo II
i will use more composite materiel , smaller and lighter . I'm just not shure if i should use aluminium ''standard style'' pontoon or catamaran ''fiber glass'' style what do you think ?
  #34
Old 08-22-2011, 07:25 AM
Rep: 205 Posts: 442
The shuttle craft seems to work very well, I actually saw one once on Biscayne Bay and it was running quite nicely. Perhaps use that size and weight as a baseline if you want to improve performance.
Unless you have a long haul to where you want to anchor up and party I think 10 knots is great, like in Sailboats, the party starts as soon as you leave the dock and doesn't end until you return, so who cares how fast you go?
I did find 2 for sale on e-bay with PWC's and I saw several more on Boat Trader.
Steve
  #35
Old 08-22-2011, 03:45 PM
Rep: 136 Posts: 421
I sold my SeaRay SeaRyder Jet boat, thought about fitting it into a larger barge but never found pontoons cheap enough. Seems you could do it with any smaller motor craft and push a houseboat/partybarge. Work out the bugs and tell us about it!
And thanks, it was the Shuttle Craft.
Can I Use 4 Stroke Oil To Burn In A 2 Stroke Sea Doo ? Sceptre Outboards 79 06-13-2011 07:54 PM
Pedal Powered Boat for the Baltic Sea / Coastline KalleA Boat Design 53 05-30-2009 11:09 PM
Jet ski powered hydroplane rgardn12 Powerboats 24 05-05-2009 12:10 AM
Amphibious, Moped Powered, Mini Pontoon Boat. BoatTron Boat Design 7 04-09-2008 10:01 PM
Ski jet in boat Powerboats 10 08-12-2002 08:32 AM
