| Pontoon Boat Design Have recently aquired a pair of 24feet x 36inch diameter aluminum pontoons. Can someone provide the equasion for how much weigh this configuration can safely hold. I am looking at making a small houseboat/floathome powered by a jetski. i hate conventional designs and am look at options. Possibly using glass, and aluminum filled with solid foam. Looking at a way to get around how boxy the thing looks.... Thanx |
| Taylor, Assume you weigh it down to a draft of 18". The load they can hold is: (36" = 3 ft, right?) (phi/4)*3'*3'*24'*Sg - "own weight of both pipes" Sg being specific gravity of water in [kg/cu.ft]
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| a liter's to kg's is easyer Peter i too was looking at the poly or aluminum covered foam panels, see the doodle. seems there rules also...and for the box: "a sharp rectangular shape can have its drag cut by 80% with a corner radius that is only 20% of the height of the body" |
| Thanx Guys, The pontoons i have are nicely tappered at the bow. Now to figure out how much they weigh... Yipster, I quite like your design... |
| 19" Dia. 110.70 LBS. per Foot 22" Dia. 150.60 LBS. per Foot 24" Dia. 180.95 LBS. per Foot 26" Dia. 213.30 LBS. per Foot 27" Dia. 229.00 LBS. per Foot 29" Dia. 267.50 LBS. per Foot 30" Dia. 282.75 LBS. per Foot 33" Dia. 345.00 LBS. per Foot 36" Dia. 407.00 LBS. per Foot 39" Dia. 492.54 LBS. per Foot 46" Dia. 690.00 LBS. per Foot |
| A bare boat with 30" dia pontoons 30' long 12' wide weighs about 1350 lbs. |
| Hi Taylor, If you're intending to use this as a boat, I highly recommend calling up your local Canadian Coast Guard office ( http://www.ccg-gcc.gc.ca ) for a free copy of publication TP1332 (1999), "Construction Standards for Small Vessels". This includes information on loading and maximum power for most boats, as well as tips on fire prevention, flotation, wiring, etc, and also the forms for getting a capacity plate (which you need to licence or insure the boat). Definitely a worthwhile 5-minute phone call.
| You have to subtract for the taper. How much depends on the exact shape, but it can be 20-25 percent for one end only, 40-50 percent if both ends are tapered.
__________________ Sailing is not a motor sport. |
| If you end up foam filling the pontoons/sponsons I assume you add in the weight of the foam into your calculations. The question remains (for me): Because there is less room for air in the pontoon/sponson when using foam (as the air trapped in cells is actually providing lift/buoyancy), what factor of loss efficency is there? Example: If 10% is a poly-foam cell structure, then the remaining 90% trapped air is what is providing buoyancy, right? |
That does not make sense, what am I missing to make sense of this? |
Sam |
Steve |
| Thank you for the explaination SamSam and lewisboats, it's starting to sink in. ![]() |
| What type of boat design is best for me | JDWeld | Powerboats | 11 | 03-01-2005 12:20 PM |
| Aluminum jet boat design? | gray webber | Powerboats | 0 | 11-27-2004 12:23 PM |
| Naval Architect Book? | Bill_Smith | Boat Design | 16 | 11-17-2004 11:08 AM |
| New Boat Design | striper | Boat Design | 2 | 08-08-2004 03:50 PM |
| Folding Boat Design | Archive | Boat Design | 0 | 06-12-2001 04:18 AM |
