| Pond Cruiser I have been asked to design and help build a boat for a friend. My professional experience has been in sea-going vessels only. Requirements: Operates only on a pond; stored dry Lapstrake, neo-classical appearance, figurehead on stem. Seat 4 middle aged non-athletic adults (women in voluminous dresses) Cruise speed 3 kts Max speed 5 kts Strongly prefer electric propulsion Would also explore a design that seats 6. Given the intended use, I'm thinking strong bilge chines and broad transom. Are there any plans already out there that might be a good starting point, or am I in completely new territory? Can this be done (reasonably well) in 16-18 ft LWL? |
| 18-20' victorian punts or wherrys are what you describe, but you say you want electric propulsion. You will want to go look at the ELCO launches. www.elcomotoryachts.com.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Paul Gartside has a handful of steam launches that should be suitable: http://www.gartsideboats.com/catsteam.php#steam132 As does Selway-Fisher: http://www.selway-fisher.com/Steamup20.htm Also Tad Roberts has a lovely electric launch available here: http://www.tadroberts.ca/services/sm...ectriclaunch15 A google search for "steam launch" will likely be helpful to you. Typically steam powered boats used very efficient hulls that convert easily to electric propulsion.
__________________ One who furrows the sea enters into a union with happiness - the world belongs to him, and he reaps without sowing, for the sea is a field of hope. |
| MatthewDS - Thanks for the pointers. The requirements set was all about slow and elegant, and I failed to consider the power levels of earlier days, and the boat styles thereby required. Alan |
| Electric Cruiser The easiest way to get a good electric cruiser is to buy a used fiberglass sailboat on e-bay, cut out the centerboard well, and glass in a propeller shaft. Sailboats with bad sails or a broken mast go for a song on e-bay, I bought mine, with trailer, for $108. Yahoo groups, electric boats, has a description about building an electric Javelin. I have been cruising with this boat for 5 years now, good for 4 adults, so something a little larger would be required for 6 passengers. |
| PV Cruiser | NWBeerkat | Hybrid | 4 | 09-03-2010 03:13 AM |
| My Little Cruiser | floridaboy | Boat Design | 14 | 08-23-2010 06:27 AM |
| Stability criteria of pond sailboats | George S | Stability | 33 | 04-04-2009 01:10 PM |
| cruiser efficiency | PT Man | Powerboats | 14 | 02-24-2004 07:16 PM |
| Outboard cruiser | duluthboats | Powerboats | 14 | 01-29-2004 04:49 PM |
