| Polyurethane for rails What does anybody think about using polyurethane glue ie Liquid Nails as bedding compound for the rails above the waterline? I have some Silkaflex, but it is white and the rails are mahogany. I'm afraid that if I use the white stuff, it will show on the brightwork. Liquid Nails is brown or clear. thanks, flydog |
| Liquid Nails are for land based carpenters, too lazy to drive in a few nails to hold something. There is no place on a boat that Liquid Nails belongs. Carefully tape off the area you don't want the "white" goo smeared all over, both the rail and the hull topsides. Apply the goo in a healthy bead and start the fasteners, until you see goo coming out of ever place. Tighten until you have about a 1/16" of gap between the topsides and the rail still showing. Smear the goo into a nice line around the rail then peal the tape off against itself (a real hard angle), so it doesn't lift the goo. Let this set up for at least two days, then dog down the fasteners good. Perfect seams and a gasket like bedding job. For a real nice job, counter sink each fastener hole before you place the rail and place a little goo around the counter sink. This will help prevent mosture form getting into places you don't want it, though no one will see it. |
| toe rails and rub rails | fishweed | Wooden Boat Building and Restoration | 16 | 03-03-2007 09:40 AM |
| 2 Part Polyurethane Vs. Gelcoat | IMPROP | Materials | 1 | 05-30-2006 06:53 PM |
| Polysulfide vs Polyurethane - Below the Waterline | Texas Boater | Wooden Boat Building and Restoration | 1 | 05-12-2006 08:50 PM |
| Polyurethane as Core Material | Victor Lemmi | Materials | 3 | 07-03-2004 02:39 AM |
| polyurethane rubber | Materials | 1 | 06-29-2002 10:20 PM | |
