| Polyurethane Foam Hey Guys, Does anyone has an idea if PU foams are used in the Boat Manufactury Industry? I'm currently looking at this solution but I am wondering if these foams are already in used somewhere by professionals ... ? Does anyone can Help? Thx Bart |
| Most rudders and centreboards for Dinghies such as the laser are made from polyurethane foam. Gareth |
| If it's the two-part foam you pour then it's not really a good marine foam. It absorbs water over time and is more of a heat insulation for dry (out of water) places.
| years ago i went to the chicago boat exibit.......they gave me a 2 part sample of it in air pressureized containers that mixed out of one nozzle....the boat we were building at the time had a deep v in it only half way then the v got smaller as u went to the back of the boat.....we thought it would be a good sound deading point....it was....then i used it for a floor job.....took out the floor and laid in the new on then i thought floatation ????????.....ok dill a small hole in the floor fill it with the foam there u go.......ok forgot about the expansion and it poped up the floor.........live and learn |
| Check some of my pics and you will see what a idiot can do with polly foam
__________________ If all else fails hit it with a hammer |
| where the pics butch........i would like to see |
| Jonny for your vewing pleasure .This boat was coverd in the stuff.The chap I bought her from is a idiot
| Click the link for the English PDF near the bottom of the page... http://www.finnfoam.fi/ You'll find this PU foam has been used in boats, although unconventional boats.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| ouch......i didnt know it came in green.....it kinda looks like my friends garage wall........lol.......maybe he tried to glue it back together with the stuff u think......what did u do about it ? |
| Wynand thats interesting. I didnt ask the chap where had worked prior to spinning the boat fundi story.I realy dont care what colour this stuff is or if it comes from outer space.Knowing him he stole the stuff . I removed about 7 garbage bags of the stuff. He used it to try and stop the leaks in the deck. Problem I could fit my head through some of these holes.No problem that six or seven cans cant fix ![]()
| Here is the proof Butch - all are green with different shades. BTW, this one was obtained with permission from a senior mining official.
Thx anyway for your income ![]() |
| Thx Guys, indeed, I didn't thought that PU in contact with water could bring such issues .. lol ... I think I will try first to use it in "free water" area lol. .. Another stupid question ^^ Do you think such foam could replace the epoxy/Glass Fiber of the body coat? Physical properties of PU could fit (weight, strenght ...). Did anyone already tried it? |
| Free of charge, Steel - polyurethane foam -Steel insulation sheets | rossgiles | Fiberglass and Composite Boat Building | 0 | 03-18-2008 07:43 AM |
| Polyurethane for rails | flydog | Boat Design | 1 | 01-30-2007 08:17 PM |
| Polyurethane Foam install | Ok J | Fiberglass and Composite Boat Building | 5 | 04-20-2006 03:45 PM |
| Welding polyurethane foam and such... | jprev | Boatbuilding | 11 | 01-31-2005 11:28 PM |
| polyurethane rubber | Materials | 1 | 06-29-2002 10:20 PM | |
