| Finnfoam is polystyrene, just better than styrox.
__________________ Only shared knowledge can grow. |
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| Most high lattitude steel boats are insulated with polyurethane spray foam. There is nothing better for keeping a steel boat warm and dry in high lattitudes. Painting it with cheap latex paints drastically reduces the fire hazzard. Brent |
| BArt01, PU foam is widely used in boats. It comes in 2 parts you mix and you pour. Example: Caorlina skiffs Underneath the floor is PU foam. that is what give the skiff to draft so little. It is used in many applications from sound supressaint to flotation. Hope this helps ya |
| Indeed that's one of the reason why I wish to you PU (instead of Styrofoam ... PU shows better isolation properties. Quite interesting in today's energy issues lolol) |
Thx in advance ![]() |
| Fiberglass is not waterproof. Over time your boat is going to get heavier and heavier as the foam absorbs the water and you will have to take the foam out again. This foam is also very brittle. If you get a break in it it is going to scharfe away and you are going to be left with a lot of powder. Same reasons why polistirene is not used. A much better option would be to fill a cavity with coke bottles, at least they won't perrish if it's flotation you're after. See if you can find closed cell pollyethelene foam instead. You can cut to size and glass it in place. Nothing beats it. Weight starts at 25kg/m^3
| You mean PU Foam I guess ..? That was one of my fear ... I have already used some for the ground, I planned to do some pannel walls for the isolation ... Could I do anything else with that??? Bart |
#25
| Not really sure why fanie is saying fiberglass is not water proof. I believe that of it wasn't water proof then the coast guard would not let companys use to build boats. PU foam is used for boats as I said earlier in the blog. Here is some info on PU foam. 2LB density marine foam is recommended for void filling in nonstructural applications. This product can be poured underneath decks and inside cavities where a lightweight flotation foam is needed to provide buoyancy. This foam has been tested in accordance with U.S. Coast Guard Regulation # 33 CFR 183.114 . This foam is approximately 95-98% closed cell which resists absorbing water, however continuous water submersion can eventually lead to loss of buoyancy over a period of years. We recommend this product strictly for flotation applications. If you are looking for a liquid foam for sculpting or casting use 3LB or 4LB density. EverCoat US Composites and there is a couple more companys. Hope this helps. Chad |
#26
| the gelcoat makes it waterproof or when no gelcoat used, the paint system. You chip or crack your gelcoat and leave it like that, I bet my best hat you will have some serious problems coming your way....
#27
| Wynand, Thats IF. In general Fiberglass is waterproof. If damaged then yes. But the overall aspect of it would be fiberglass is waterproof. |
#28
The foam does absolutely nothing to help the boat draft so little. If anything, the foam will increase the boat's draft as it gradually absorbs moisture and becomes heavier.The only purpose of that foam is to help keep the boat afloat if it gets swamped ... and this is may do if it hasn't already become saturated. Quote:
Polyester resin slows the flow of water but it is essentially porous when used in the construction of a composite fiberglass hull. Vinylester slows the flow of water better than polyester but it still exhibits the same type of porosity as polyester although on a lesser scale. Epoxy, the best performing (and least used) of all the common resins in fiberglass composite construction, is still not totally waterproof although it is far better than the other two plastics mentioned here. ---------------- Chad, there are many knowledgeable and experienced people in this forum, so when you don't know the facts it is generally better to remain silent and learn ... rather than making claims that many of us know to be false. ![]()
__________________ Kenneth Grome |
#29
| we use a 2 component foam from finnfoam, its easy to work with and it does not expand like the polyurethan foam. send a mail to them www.finnfoam.fi and get a small sample....
__________________ Harold www.rivadezza.com |
#30
| Ok I guess most of you are speaking about those sprayable foam, I am more thinking about these rigid panels? Thanks for your Help Bart |
| Free of charge, Steel - polyurethane foam -Steel insulation sheets | rossgiles | Fiberglass and Composite Boat Building | 0 | 03-18-2008 07:43 AM |
| Polyurethane for rails | flydog | Boat Design | 1 | 01-30-2007 08:17 PM |
| Polyurethane Foam install | Ok J | Fiberglass and Composite Boat Building | 5 | 04-20-2006 03:45 PM |
| Welding polyurethane foam and such... | jprev | Boatbuilding | 11 | 01-31-2005 11:28 PM |
| polyurethane rubber | Materials | 1 | 06-29-2002 10:20 PM | |
