Old 04-20-2009, 02:48 PM
Tore_M Tore_M is offline
Rep: 10 Posts: 4
Plywood Offshore catamaran approx 18ft
I want to design my own boat in plywood, but there is a long way from just thinking to actually building. This is what I'm thinking about.
Where should I start ?
regards
Tore
Old 04-20-2009, 02:59 PM
Previous Member
Rep: 0 Posts: 0
Start with a known, well behaved hull that has a known engine package that is within your budget and take some general reference measurements from the chosen example to get you started. It's going to be pretty difficut to replicate all the chines and strakes of that illustrated hull in plywood as a straight-up build, but you can come decently close by building the general, background form and then applying surface strakes as necessary.
You may wish to take your newly acquited measurements into an easy to manipulate program, such as Carlson's Hulls (freeware on the Web) and start roughing-in the base shapes. Hulls files are importable in Freeware, where you can get more accurate readings on the hydrostatics, etc.
Both of these programs can output very nice .dxf files, as well as offsets for the cutting of the plywood. The .dxf files can be taken to a CNC router location and you can get the hull panels cut precisely, if you like.
Anyway, that's the way that I would do it if it were my project.
Plywood Sailing Catamaran! Bluewater64 Boatbuilding 14 05-04-2009 07:20 PM
The Ideal 18ft Daysailer Paulo.AS Sailboats 25 10-06-2008 07:58 PM
High performance offshore catamaran boat mold wanted 26' to 50' Travis Pettko Boat Molds 7 01-07-2008 07:29 PM
Personal Offshore Catamaran Design JCD Multihulls 45 07-12-2006 07:48 PM
Plywood Catamaran petee Wooden Boat Building and Restoration 8 08-16-2005 01:51 AM
