| pls help hi folks pls help me calculate the stability of a toy boat, i built a toy boat but now the problem is that it is no stable in water and it does not move in a straight line, i would like it to move in a straight line. ![]() |
| got a rudder?
__________________ Are we off-topic yet? |
| No calculations help here without drawings of your model but… If you have any extra on the top sides like thick masts or antennas, try removing them and maybe add some small weights at the bottom of the hull, stones work well. Adding a keel helps for directional stability, something like a pencil or a steel rod, if you need the ballast. Do you have a image you can post. |
| answer I don't have a ruder and drawings at this stage |
| Help Pls | khumalop3 | Boatbuilding | 14 | 08-10-2006 03:21 PM |
| Boat Stability help pls. | trouty | Boat Design | 11 | 10-28-2005 10:55 PM |
| pls help | georgio | Boat Design | 1 | 06-24-2005 09:57 PM |
| need series 64 hullform. pls help....... | gmjoarder | Boat Design | 1 | 04-18-2005 07:35 AM |
| ISO 47.080 Educate me pls | ErikG | Boat Design | 0 | 06-18-2003 03:47 PM |
