Old 05-18-2003, 06:01 AM
nico nico is offline
Rep: 52 Posts: 186
Plexiglass maximum radius curvature
Hi,
I am looking for any infos on the maximum radius of curvature plexiglass ( thickness used for sailboat below 60') can support without breaking.
Thanks
Old 05-21-2003, 06:40 AM
Zaynab Zaynab is offline
Rep: 10 Posts: 19
I do not know the maximum radius. We had to get curved plexiglass sliding hatches. Since the curvature was too big to just bend the plexiglass a mold was built over which a piece of plexiglass was "baked" in an oven. Apparently you can also do this by heating up the plexiglass with a hair dryer.
Old 05-22-2003, 03:03 AM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
plex info
I am not sure about maximums most of the time we were concerned with minumums. Be sure of the grades of plex there are many brands and furmulations designed to different things. If you are here on the states look for your larger sign shops (big towns) that have a vacuum forming set-up. allthough you may have to do some sweet talking to get them to try the thicker materials windows and such would require on a vessel of your size. Pack a lunch if you are going to get much thicker than .25" I think you would be in for a long wait with very inconsistent temps across the panel you are trying to bend. we used strip heaters (like the elements in an electric oven)to make tight bends. You really do need an oven and mold if you are looking for a gradual bend. Keep in mind that most acrylics are really undersize
EG 1/8" is really sold as .118 not a full .125" +-.003
some manufacturers are CYRO and ROHM & HASS. if this helps good if not im sorry to waste your time. Good luck!
8Kts
Lift and drag coefficients for sails and foils poul Sailboats 16 02-17-2009 07:42 PM
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 08:04 AM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
What is "twist" in a developable surfaces program? Ian Software 5 09-07-2004 07:14 AM
Dix Radius Chine Designs bjl_sailor Boat Design 11 06-15-2004 10:26 AM
