Old 03-16-2008, 06:37 PM
grant1963 grant1963 is offline
Rep: 10 Posts: 2
plate aluminium boat kit
Guys,
I want to build a plate aluminium boat, 6.0 -6.5m cuddy cab design. Interested in a flat pack kit but would prefer to source and cut my own plate.
It will be mainly used in the ocean for diving, we get caught in all sorts of weather so it must perform is hard conditions.
Have seen some great designs of boats in Perth but shipping costs are a killer.
Can any one recomend or sell me a design, or point me in the direction of someone who can.
Cheers
Grant
Old 03-16-2008, 08:07 PM
lazeyjack
I have a couple, I built 4 of the 6m boat, with very deep fine entry
it had wide chines, and was the sorftest running boat outrunning everything in choppy seas
I will try find the paperwork for it, we built all 4 as cuddies using 140 2 cycle yamaha at the time ,
i will find pic and scan it send you pm
Ann there is a red boat in my gallery with similar bottom, that is an 8m boat
Old 03-16-2008, 08:11 PM
Rep: 10 Posts: 2
Thanks heaps Lazeyjack, look forward to the pics and anthing else you can provide, cheers
Old 03-16-2008, 08:26 PM
lazeyjack
this is the one, you see the wide chine disguises the depth of vee, deadrise aft is 22
I made a machine to put a joggle in the topside plates of all my trailer boats, since I stopped building I sent the machine to scrap, pity
Old 03-21-2008, 02:35 PM
kmorin kmorin is offline
Rep: 230 Posts: 185
Side Joggle Machine
lazeyjack,
You mentioned a machine to joggle the topsides of your trailer boats, did that resemble a big version of a bead roller?
Wondering if there were top and bottom 'arms' reaching to the middle of a sheet- (1.5-2m) and holding a set of concentric/nested profile rollers forming a ridge or dip in the sheet?
From the photo I'm guessing the joggle was a 'Z' section(?) but the small photo's not telling all.
Do ya' happen to recall the radiuses you found best suited for different alloys? Any guidance would be appreciated as I'm trying to build something similar for 5052 and 5086 -but only up to 0.125"- 3mm material.
Thanks for any time to reply.
cheers,
kmorin
Old 03-21-2008, 04:14 PM
lazeyjack
i went to the scrap yard, I bought a big old reduction gear so the travel speed was 2 feet a min, I , I had some big pillow block bearings also from scrap and a 2 inch high tensile shaft for the driven roller, the squeeze was put on by a second roller on top mounted on a screw thread(old fashioned truck jack from memory the radious on edge of each roller was 15mm, the rollars were 150 dia from 2inch thick steel I rigged a pointer on the machine, drew a line on the plate and fed in with no weight on then screwed down slowly and with one man at the switch and the other at the end of plate worked down the line, the man at switch eyes the pointer and the guides the man on end of plate, It is bloody nerve racking but some of ours were 8m, we never had any mistakes or chuck aways, we only did to 4mm I would hate to buy all thsoe components new
The roller ended up abt 300 mm from ground level, adn we used timeber to bring plate to same level
The sqeeze never ever closed the rollars to 3, or 4mm or whatever, the joggle was slight, I was the first to do it in NZ, later I will sketch it, But in answer to the first question, I can only find plans for 7 -9 m boats, I gave the 6m to my prentice, and he died, which was a huge shock to me
Old 03-22-2008, 03:00 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by grant1963 View Post
Guys,
Cheers
Grant
Grant
This company may be one to try:
http://www.platealloy.com/6metre.htm
I have not had anything to do with them other than correspond with their naval architect but they were obliging enough. Not sure if they will sell plans separately though.
Rick W.
Old 03-23-2008, 03:29 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
grant1963,
It might seem bizarre, but the Tolman Jumbo could be worth your consideration. Yes, it's marine ply/epoxy/glass, but Alaskan waters are its home waters.
http://www.fishyfish.com/tolmanskiff.html
Here's a bit more from another very good site.
http://www.amateurboatbuilding.com/a...man/skiff.html
I have often wondered if the Tolman could be reproduced in aluminium. It's basically built from five panels, including the transom.
Good luck, there's much to read.
Pericles
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 03-23-2008, 07:17 AM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
plate aluminum boat
YOU MIGHT look at specialty marine contractors. Lots of plans-located in Oregon plus elsewhere. Stan
Old 03-23-2008, 10:00 AM
Pericles's Avatar
Who might look in Oregon, rasorinc? grant 1963 is in Oz and I'm in London and I've got the Tolman and the Devlin books.
Pericles
Old 03-23-2008, 11:18 AM
aluminum boat
specialty marine AKA Specmar is one of those other places.
SpecmanAus@bigpond.com
Old 04-24-2009, 07:03 PM
Remoosed Remoosed is offline
Rep: 10 Posts: 2
Lazyjack I'm a retired welder, trying to get ducks in a row. Want to build a boat like the one in your picture,at home with some coffee shop friends. Please let me know what I can do to get your plans. I we want to buy,cut,weld everything ourselves. Thank you Remoosed
Old 04-25-2009, 12:55 AM
plebusmaximus plebusmaximus is offline
Rep: 10 Posts: 22
Have a look here: http://www.platealloy.com
There is plenty more. Lofting your own is a big job.
Have a look around and speak to some builders. There would be some looking for work at the moment.
Have the hull "aluminium only" built and do the rest. It may work out cheaper.
That's enough on its own to keep you busy for a while.
Where are you in Australia Grant?
fear leads to anger, anger leads to hate, hate leads to paranoid borderline personality disorder.
Your alive, be happy.
Old 04-25-2009, 06:31 AM
Rep: 10 Posts: 2
plebusmaximus Good advice. In the last few mounths I've bought a used plasma cutter, bandsaw and drafting table. I'm now building two 4x8 adjustable rollaround tables. I'm looking for a used Miller 350p with push pull gun. Plus a water cooled tig. I would like to find, buy,con,get some plans close to what we want to build. I learn buy doing, however I make every mastake five times. I'm at this forum to cut down on my mistakes. Looks like my first mastake is not buying a precut kit. I think (know)I can build aboat. Designing a boat is way over my head. Thank you Remoosed
Old 04-27-2009, 02:47 AM
aussieav8r aussieav8r is offline
Rep: 20 Posts: 13
Boat design
Hi grant I might be persuaded to sell a copy of my plans so that you can make up your own boat , the drawings are not fully detailed and are for the basic hull design but with a little skill you can fit out however you like
I cut the complete boat out using a circular saw it was easy and fun and went together very well .
See it under the 5.6 meter centre consul heading on the forum 5.6 meter Plate alloy home design
Use the link cut and paste it in your browser
Plate alloy kit construction? marco.. Metal Boat Building 2 08-17-2006 11:41 PM
aluminium plate boats daedong Metal Boat Building 6 07-02-2006 04:09 PM
kit boats - boat plans aS__iS Boat Design 7 06-06-2005 02:40 PM
Pontoon Boat Kit Boatbuilding 5 11-04-2004 03:29 PM
Plate thicknessand other scantlings for aluminium construction Willallison Boat Design 14 05-20-2004 08:11 AM
