Old 11-30-2009, 08:56 PM
jdworld jdworld is offline
Rep: 50 Posts: 61
Plastic Trim Part Fabrication
Where would one go to get custom designed one-off plastic trim pieces made? Say for example you needed some interior trim rings made to match some custom shaped windows on a houseboat. OR maybe you wanted / needed a custom instrument cluster manufactured out of plastic. There's a lot of custom boat designers and builders on this list, and I'm sure with many of the boats that get built there's surely some custom plastic pieces that need be made. Where do you go? Thanks!
Old 12-01-2009, 07:32 AM
Greybarn Greybarn is offline
Rep: 10 Posts: 57
We either design and build them in-house, or design them and sub them out to CNC shops.
Old 12-01-2009, 09:34 AM
Rep: 3125 Posts: 9,398
These sort of thing don't have to be difficult. If you have a good production run to perform, then you have many options, but for one offs, 'glass over or in a mold, will suffice quite well.
A wooden representation of your port trim could be easily carved up. A female mold pulled from this in vinyl, latex or rubber and a cast laminate built up in the mold, possibly with pigment added to make over coating easier.
It would be helpful to know what you're attempting, how many, in house facilities, etc.
Old 12-01-2009, 10:37 AM
wardd wardd is offline
Rep: 443 Posts: 925
clay master, plaster mold, vacuum form
you can do it at home
Old 12-01-2009, 11:12 AM
Rep: 50 Posts: 61
Wow - so you would actually try and do it yourself then. Ok, I've done a few little latex mold plastic pieces before. And get the clay or wood master with a latex or plaster mold concept. But the DIY vacuum forming I haven't done since using a big industrial machine once or twice way back in high school. How can you do this at home ? I would love to get this stuff down. I'm a total DIY guy and it would open up a whole new world of possibilities if I could somehow make the parts (at least functioning prototypes) myself. Although trying to carve up and mold something as big (and thin walled) as an instrument cluster seems unwieldy, but maybe? What does CNC stand for?
Old 12-01-2009, 11:29 AM
Rep: 443 Posts: 925
if you seal the plastic sheet to a box with heater coils in it you can use pressure to force it over the mold just put vent holes in the mold
Old 12-02-2009, 04:12 PM
kerosene kerosene is offline
Rep: 175 Posts: 420
CNC = computer numeric control
means you create a 3d-model in a modeling software and a computer controlled milling machine mills the shape out of material of your choice. accurate but expensive
Old 12-02-2009, 08:40 PM
Rep: 50 Posts: 61
ahh right, have seen that on tv. any example of costs?
Old 12-02-2009, 09:01 PM
Rep: 175 Posts: 420
I have no recent experience but on one off parts one grand doesn't get you much - someone else can chime in.
Trim tab options between bennett and kplanes? Lenco trim tabs? Red Tide Powerboats 5 11-19-2009 06:59 AM
Spar Fabrication ? GOTTABSOMEWHERE Boat Design 5 08-13-2008 03:52 AM
Windshield fabrication nalbercj Boatbuilding 0 06-29-2005 09:23 AM
Recycled Plastic/Plastic Lumber Hulls for Pleasure Boats? Keith King Boat Design 8 09-29-2004 01:17 PM
plug/mold fabrication cfox Boat Design 8 06-23-2004 10:55 AM
