| Plans for aluminum layout boat? I'm thinking about building an aluminum layout boat - have seen plans for wood/glass but nothing in AL. I like the light weight and durability but I'm hesitant to work off wood boat plans (http://www.marsh-monster.com/boatbuilding.htm) Anybody have any plans or suggestion? |
| ...personally, never heard of a layout boat before, but understand now that I have looked at the web site. ...there is absolutely no reason not to build in alloy, it is a simple boat construction and light weight, alloy would be a good material, but it will be cold in the winter of course.
| Alloy will be noisier, with even ripples causing audible sounds, which might not suit your application. |
| We call these types of boats duck boats. I'd agree the idea of a duck boat or blind is to remain relatively out of sight, out of mind for whatever you are hunting. Aluminum wouldn't lend itself well to this task, even though it would be a good material for construction. |
| Why Aluminum? That design looks like it would be prefect for glass, though I would consider putting some foam around the perimeter for buoyancy in case you get swamped, which with an open cockpit and a freeboard measured in inches seems likely. I would also consider a spray skirt for actually using it. |
| Why AL? For one, that's what I know - I've toyed with glass ever so briefly and it isn't my talent. Also, AL is light, strong, repairable and readily available. Cold and noise are trade off's to ease of construction and weight. I'm hearing that this is not a smart project, better to figure it out now than later. |
| Not saying it's a bad idea, just making sure you understand the trade-offs. If you're comfortable working in aluminum then that's a strong argument for using it. If the noise and cold aren't issues, then it should work. I know a lot of duck boats are made in aluminum, though to a more conventional shape. |
| Iam looking for plans for a "layout" boat | MP Sniper | Boatbuilding | 6 | 10-12-2009 10:32 AM |
| Bare Aluminum Boat- Need Help Starting Electric Layout | wfcperrine | Electrical Systems | 6 | 03-01-2009 09:02 AM |
| small boat plans in aluminum | dandude | Metal Boat Building | 7 | 01-21-2006 04:15 PM |
| Aluminum Jet Boat Plans | Trigger | Metal Boat Building | 16 | 07-11-2005 01:25 AM |
| Aluminum Jon boat plans | Matt F. | Boat Design | 30 | 08-31-2004 12:41 AM |
