| planing hull / air prop is it feasible to use hovercraft type powertrain on a planing hull . Would there be problems with heeling/turning . The areas I am thinking of using the boat are lagoons where sometimes the depth is only 1-2 ft . I know this because my sailing canoe has a 2 ft centreboard .undefined |
| Yes, they are called airboats and have been in use in the southern USA for about 80 years. http://www.airboattrader.com/ |
| The big hassle is THRUST . An air prop will convert 1 hp into about 5 lbs of push (7 with theoretically Perfect prop) A water prop will easily produce 20 lbs of push for each HP , with 25 or 27 not unheard of. So are you willing to have and feed an engine 4 or 5 times larger than a wet prop would need? FAST FRED |
John |
| thanks for the replies . I am aware of airboats but what i was picturing in my head was a conventional deep/medium vee speedboat hull with a inboard engine mounted low in the hull driving one or two airprops , therefore having nothing to damage below the waterline and capable of going from lagoon to river and then to sea . |
| If you're not going into much less than 1 foot of water, check out www.smithboats.com/whoweare.htm. Inboard + shallow draft = powervent ![]()
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
| sea ray prop for planing | jfc52 | Propulsion | 20 | 09-17-2004 09:09 PM |
