Originally Posted by BertKu Last week I bought a lathe/milling machine and 316 stainless steel, because the engineering company tried to convince me that 304 is good enough.
Bert |
Off topic for this thread, but if the machine you bought is one of those 3 in 1 lathe/mill/drill combinations, good luck on your 316 stainless. The cheap 3 in 1 machines are fundamentally useless for any of their purported tasks.
Second point, depending on where the stainless was to go and what it was to do, perhaps 304 was good enough. Hell, I use 303 for some things because it machines so beautifully. Not below the WL exposed to salt water however.
On plans, I bought mine from a designer who'd actually built 5 hulls himself from his design, in his own yard. I've nearly finished welding my hull together and the only real problems have been mine due to lack of experience and regardless, it's come together fine. If I were to build another one of the same design it'd be a lot faster and if I decide to build a larger boat in steel I'll buy the plans from the same designer as I know the hull can be built to the plans provided.
PDW
