Old 06-10-2010, 04:40 AM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
performance
excellent stability of planing hulls? how to achieve it?the best trim angle how to maintain it at different speeds?
Old 06-10-2010, 06:48 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Given a particular planing hull and loading, the boat will assume the equilibrium trim angle necessary to generate the dynamic lift required to support the boat at that speed. Lower the speed and trim angle increases, raise the speed and trim angle decreases. Increase the load, without changing balance, the trim angle will increase and vice-versa.
Sure, its more complicated than that but that is the basic principle at work. If you want some dynamic lift, some trim angle must be taken. Zero trim angle generates zero lift.
Trim angle can be forced, as in step hulls or changed with trim tabs, etc. Most designers say that a trim angle of 4 to 5 degrees in a monohull planing boat gives a minimum sum of wavemaking and frictional drag.
Tom Lathrop
What defines performance? Lourencosampaio Sailboats 13 10-01-2009 06:54 PM
Want more speed and performance!!!!!! MarioCoccon Sailboats 9 08-23-2006 03:38 PM
performance racing schwing Boat Design 2 12-17-2004 07:53 PM
30 Plus Performance CC Molds..... Wardey Boat Molds 2 05-27-2004 06:23 PM
Prop performance danmarine Boatbuilding 0 05-20-2004 12:58 PM
