View Poll Results: Please pick your poison
Trawler: single Mitsubishi 15 35.71%
Trawler: twin Luggers 11 26.19%
Yacht: single Grenaa Diesel 14 33.33%
Yacht: twin Mitsubishi“s 2 4.76%
Yacht: twin Luggers 4 9.52%
I am fine with less accommodation in favour of a large engine room. 28 66.67%
I prefer large accommodation, the engine room is second. 2 4.76%
Multiple Choice Poll. Voters: 42. You may not vote on this poll
Closed Thread
  #181
Old 10-19-2010, 02:10 AM
mark775
Read this. It is redundant and Bureaucratspeak but basically says no matter what precautions one takes, incompetence will prevail: http://www.pwsrcac.org/docs/d0028900.pdf
"The Inadequate Implementation of Planned Maintenance Program and Failure to ensure planned maintenance program were followed" are reasons that the Selendang Ayu failed (that, and the fact that so much time was wasted calling for help, saving money by hiring too small a tug, CG errors, tug errors, waiting too long to evacuate, the list is long...come on - calling by VHF ninety miles? One might get 36. Waiting a day before using the phone? Sounds like they were trying to avoid fines associated with a host of safety violations. Not one of the faults was "not having enough engines")
You spent a little time on a cruise boat and had failures every year. You stated "...lost both Zs due to a hydraulic failure." "...ate a mooring line and lost the sacrificial gear in it's transmission." This is FAR more likely to happen with twins - sorry. It is my contention, and the same with a majority of professionals worldwide, that two engines are more likely to cause failure than one (More complicated systems, for example, were a factor in the hydraulic failure you mentioned. There is no doubt. Only those that do not know insist on redundancy in propulsion. Fire systems are already required.
One last thing. Are the engines you propose truly redundant? That means that the vessel could perform related manuevers on one if the other were to fail. Otherwise, a twin engine boat, but of the size of the Selendang Ayu wud not have been able to turn the bow into the weather anyway and if the damned engine wudn't run because of insufficient compression (one cylinder happening to fail was just a symptom of a poorly maintained engine and not the cause of the accident), then two wud simply have twice as many cylinders with insufficient compression.
All of this being said, you are not going to change the mind of a professional mariner by citing an example where third-world maintenance was the first link in a tragedy. Not only THAT, the matter is settled. Richard is not building a sportfishing battlewagon or such and this thread is not the place for that discussion (I think that was already covered - it might take five minutes). Double hulls, quad engines, dual everything, are the realm of the ignoramus and the politician (and to be generous, the naive) and are no substitute for doing one's job.
  #182
Old 10-19-2010, 05:41 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
I'm convinced.
Hoyt
  #183
Old 10-19-2010, 12:31 PM
apex1
Originally Posted by cthippo View Post
Every single year I was on the boats at some point we had an engine failure requiring replacement of parts. I'm also not buying the "lack of maintenance" story. We had excellent engineers, most of them retired Navy types. These are amongst the worst!
One year we lost both Zs due to a hydraulic failure, another is was a blown voltage regulator on one of the gensets (which also took out our bowthruster). That same year one of the other boats in our fleet ate a mooring line and lost the sacrificial gear in it's transmission.
My point here is that modern engines are a collection of many parts and sooner or later some of those parts break. Had any of the boats I worked on been single engine we would have been adrift.
If everything goes right a single engine can be fine, but the problem is that it doesn't always go right.
For an inland vessel I think a single engine, well maintained, is fine. For blue water cruising it just seems like too big of a risk.
Thats just not true, as millions of single engine ships prove every day.
On a related topic, That is not a related topic! You should read the related threads I opened!
I would also want to have an engine room fixed fire detection and suppression system.
You should have read the thread/s before you contributed. (contradicted)***
When your engine failures were so regular, you either worked for a stingy company buying cheap crap, or your engineers were far away from being highly skilled pro“s. (I assume the latter, having met some Navy "pro“s". Most are from the "Parts Replacement Division")
As Mark mentioned, the chance to catch a rope are far better with a twin set, than with a single engine, and almost always you have your catch in both props.
But it is moot to discuss twin or single engines for these vessel here. The votes and my decision are clear (and according to our professional experience), single!
Originally Posted by powerabout View Post
I dont think a modern 3600rpm engine will produce much at 1500, time to check out the power graphs.
The graphs will not tell you anything, because when the engine is derated, they change dramatically. And of course you loose torque, as you loose power. But when done right, you have most likely much higher torque with a derated engine, than with a smaller displacement of the same power.
Originally Posted by mark775 View Post
Perhaps I already missed it and, if so, I apologize but is an engine that is designed to run on bunker okay when bunker is not available? There is no longer any bunker fuel refined in Alaska, for example.
Good question Mark.
The answer is simple. Yes the Grenaa is happy with car Diesel or any other medium destillate, as long as it is below 5,5 centistoke (without preheating). Being a European design of the late 60ies (relatively modern) it was already thought for low sulfur fuel.
The other engines in question have been never designed for MDO bunkers, so nothing changes.
The Grenaa will have a bit less power with ordinary car Diesel than with MGO/MDO though, due to the lower energy content. But I doubt one will notice any difference with these monsters.
Regards
Richard
The perfect Passagemaker? (style within this genre)
The perfect Passagemaker? II (building material)
The perfect Passagemaker IV, Equipment
  #184
Old 10-19-2010, 12:44 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
Originally Posted by apex1 View Post
you most probably have the old "Bosch" type injection pump which has to be partially replaced. (other pistons and timing) And adjust the governor if not built in.
But most suitable engines you might think about, are, or have been on the market at least as generator units, if not as marine engines. So getting the right parts should be not a real task.
It's like you said above, an unused Westerbeke 71C.. Bought it from a local distributor with a bargain price a couple of years ago (they were not anymore passing the new "green" regs). Anyway the (Westerbeke) has used the same blog both in gensets and in their 50 and 60hp models. Isuzu made engine and originally designed by the-best-known-english-diesel-manufacture-which-I-just-dont-recall-right-now And this lowsy mobile broadband isn't working properly... so I'm sitting frustrated in Vadsų right now
Anyway.. just had a thought if Jeff should move this side track of modifying smaller engines to a new thread..
BR Teddy
  #185
Old 10-19-2010, 01:30 PM
apex1
Teddy,
a Westerbeke was thought to be operated at 1500 or even 1200 rpm in gensets. So, no prob to derate that fossile!
The "green" question is another animal though.
  #186
Old 10-19-2010, 01:46 PM
TeddyDiver's Avatar
Gollywobbler
I take that "fossile" as a compliment The "green" doesn't concern me, as a self builder I'm not under any legislation (boat directive,environment etc) anyway so long as everything "hazardous" (me included) stays onboard and I'm not selling it..
  #187
Old 10-19-2010, 02:11 PM
apex1
What else.
If I don“t like them, who does? The choosen Grenaa is the best proof.
Closed Thread
The perfect Passagemaker? (style within this genre) apex1 Boat Design 389 02-12-2011 09:12 AM
The perfect Passagemaker? II (building material) apex1 Boat Design 126 11-13-2010 09:45 AM
alternate perfect passagemaker ideas magwas Boat Design 34 08-20-2010 02:52 PM
Titebond III testing longfellow Wooden Boat Building and Restoration 161 06-24-2010 12:58 PM
Bluenose III abckits Sailboats 2 09-05-2006 05:41 PM
