#1336
| I would like to create a freely available collection of data about human powered boats including a calculator based on this values. If you can pass me information about human powered boats, I will collect it and make the information available. This may help anybody interested in building his perfectly fitting purpose built boat. Interesting would be:
I will try to find correlations in form factor and wetted area which will lead to a formula for realistic calculation of future boats. Best regards, Andreas |
#1337
#1338
| The APC 20x15E prop is 1.06" wide where it attaches to the hub. That is a fairly large size to fit inside a U-channel then tuck in behind a spinner. I could increase the diameter of the spinner but smaller would be better to reduce drag and not catch weeds. If I trimmed the prop root down from 1.06" wide to say 0.50" I could use a smaller spinner but I'm concerned that I would weaken the prop root too much. I'm thinking that a purpose built folding prop would be a better choice. Dave |
#1339
| Hi, coach: Yes, on purpose built folder. Cuts losses from breakage and bent tips under load plus you get more efficient custom blade design and possibly smaller diameter. I haven't found anything that is really weed free, except maybe with light vegetation. Have tried folders, weedless troll props, cutters. One of several reasons that Rick mounted the folder within arms length to clear weeds. Lifting the prop to clear the water and spinning to fling off weeds works well for me, but there is still the occasional hand clearing required. A reverse auger built on the surface of the flex shaft might help by keeping weeds away from the prop. I never did find the right pitch and depth to the stairs in my application. P. Quote:
#1340
#1341
Dave |
#1342
P. |
#1343
| I like that idea of variable depth selection for shallow water! I'll be keeping that in mind. Three settings, full, shallow and stowed. |
#1344
| Rick has just uploaded a new video. A carbonfiber folding prop! and I like the peddle crank system. cool. |
#1345
| Do you have a link there Spidy-man? -Tom |
#1346
| did the youtube video not post? it shows on my end, oh well, here's the link: http://youtu.be/ONk3fUnHamI http://youtu.be/ONk3fUnHamI Rick has some slick stuff going on there! I was thinking about using CoachDave's bicycle frame idea but it's too tall, then I see rick's peddle and crank, ooooh I like! That would be be nice and low. I got to figure that I'll have sails above my head at times, so low profile would be good. I'm even thinking about changing up my center platform idea a bit. I keep molding the clay and it's starting to take shape. |
#1347
| The space is there but no link... -Tom |
#1348
| Tom Try typing in the search area of YouTube CF_Blade_Propeller.wmv Ian |
#1349
| Sorry, I wasn't very clear. The first post didn't show the link but the second one did. I had already found it by Googling: rick carbon prop v15 What I'd be more interested in would be any dialogue that may have gone along with it. -Tom |
#1350
| Rick doesn't seem to talk much. I would like to read his comments also. |
| Propellor for pedal powered catamaran | Tiny Turnip | Props | 38 | 03-18-2013 10:03 PM |
| Electric motors for solar-powered boats | Twointense13 | Boat Design | 3 | 01-07-2011 08:21 PM |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| Human-powered boats and submersibles | RatliffFranklin | Boat Design | 0 | 05-08-2007 01:36 PM |
| Bugatti engine powered boats | rivaaquarama | Powerboats | 0 | 06-08-2006 04:26 PM |
