#691
Something like that 4HP racer will be my first solar boat. It is not intended for racing on the Murray. The stern was to take an outboard. Actually flat sterns cause squat not lift. They work on a planing hull by initially sinking the stern to get the bow-up trim for better lift in the mid sections. |
#692
| Greg K has been making steady progress up the inside passage of Vancouver Island on a shakedown trip. It has been interesting monitoring his track on his web site: http://adventuresofgreg.com/blog/about-2/ There are 10 minute updates on the track and you can display the last two hours on the large map by clicking on the appropriate command button. He has had some interesting experience with the tidal flow trying to make the best of it when it is with him and hugging the shore to minimise impact when it is against him. |
#693
| Folding Weed Free Prop. Finished at last, this has a 406 dia. with a 610 pitch. the pivot slot is 6.5 wide and I had to open out the rest of the slot to 9.5 so that the twist of the blades would not jam up when folded. Dennis |
#694
| Looks like really good work, thanks for the pictures, Ian. I can see how the blades remain partially deployed to get a bite into the water and swing out for an even balance. My RC props folded back much further than that, so the blades almost touched behind and sometimes wouldn't deploy evenly. But I am rigging a restrictor that should fix. Since the RC blades are much lighter, I may have to put a pinch of lead on the ends to increase the centripetal force... Porta |
#695
When will you be testing it. |
#696
| DennisA, that is a thing of beauty, sheer artwork! |
#697
| Pedal the Ocean Just read Greg K's trip report, 314km in 2.5 days is impressive. It would be an interesting to compare with the two guys who paddled across the Tasman in their double kayak. With them both had to be paddling to make progress and they were exposed to the elements. Greg and his mate stayed inside and just kept going, one on and one off never stopping. Ian |
#698
| folding prop Did a little more testing on my folding RC prop, solving the uneven prop blade deployment. The good news is that the the prop is much more rugged than I thought it would be, absorbing bottom hits without any apparent damage. Also, there is no tangling whatsoever in the prop blades themselves once power is stopped as everything drops off the blades in the folded position. Having to stop and clean fixed blades was sometimes a time consuming issue with fixed blades. The downside is that the flex shaft itself gathers and funnels weed strands downward to the prop spinner area where these weeds bunch up and cling to the shaft. Even powering the shaft in reverse does not clear weeds from the shaft unless it is done immediately before any kind of considerable buildup. Sensing early accumulation is almost impossible with a motor, but might be possible when pedalling. So I couldn't get much improvement on completely weed free performance. Powering the shaft in reverse loosens the accumulated clump on the shaft itself, but does not fling it clear like when it is on the fixed blades. Some removal by hand is still required, although it does go faster than when tangled in the fixed blades themselves. Hope this helps. Portra Quote:
#699
The hydrodynamic drag was only part of the problem. The bluff cabin presented huge windage from the forward direction so was good for sailing them backwards. The aim with Within was to have a boat that could make way in extreme conditions. He should be able to make progress in 60kt winds. Not fast but enough to get away from a dangerous shoreline. As it is the CTD guys made it across the Tasman and Greg has yet to do something of similar magnitude. |
#700
Have you got any pictures of what you are using or links to where you got the prop? |
#701
| RC prop Rick, hope this link works: http://www.hobby-lobby.com/10x8_cam_..._38mm_spinner_ This is not really a very rugged prop, but the price was right, it was in stock and delivery was fast. I didn't want to waste money on a concept which might not work in springing for a higher quality to start with. I will try to get a picture of the shaft setup to your website and some links for better candidates in a few days. Vic Quote:
#702
| Rc prop #2 Oops, Try this one, specify 2 blade and folding then scroll down to 10X8 $19.99 USA. Hope this one works. http://www.hobby-lobby.com/elecprop.htm Quote:
#703
I have attached a pic of the prop so others do not need to search for it. How much force do you think you could safely apply to the cone with the blades supported within 1" of the tips? There is also a 16.5X15 blade set that is getting closer to what would be useful on a pedal boat: http://www.hobby-lobby.com/16.5x15_c...e_835_prd1.htm |
#704
| I've seen websites with the peddle kayaks, but don't know anyone who has one. I thought it would be neat to alternate between paddle/peddle, but doesn't the setup very much limit what the kayak can do?
__________________ ~ It's a man's world...I just float in it ~ |
#705
A recumbent seating position is very comfortable for long distance. It is much easier on the body than paddling, rowing or upright cycling. The pressure is spread between back and buttocks. Trying to paddle at the same time is awkward and energy sapping. If you want to try a nice pedal boat you could chase up Mike Lampi. He lives in Seattle so not too far from you: http://www.openwatercycling.com/ You should probably sit down before you ask the price of a Cadence though. One nice feature of powering with pedals is that the hands are free to eat, read, photograph, fish or whatever. If the pedal boat is well engineered it will just be a little heavier than a kayak but, operationally, it does not need to be much different. It takes some design effort to overcome issues with prop fouling if there is weed but there are ways to achieve this. The top speed of a pedal boat is quite a lot higher than a paddled boat for any individual and the sustainable speed is a little better with pedal power. |
| Propellor for pedal powered catamaran | Tiny Turnip | Props | 15 | 02-05-2012 07:27 PM |
| Electric motors for solar-powered boats | Twointense13 | Boat Design | 3 | 01-07-2011 08:21 PM |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| Human-powered boats and submersibles | RatliffFranklin | Boat Design | 0 | 05-08-2007 01:36 PM |
| Bugatti engine powered boats | rivaaquarama | Powerboats | 0 | 06-08-2006 04:26 PM |
