#631
I have had this sort of problem many times with Delftship and Freeship. Shame, it is a great program for many things, but these sort of problems and its occasional inaccuracy are very disappointing. Leo. |
#632
Vic/Porta |
#633
| Leo I checked this one. Delftship had waterlines higher than the aft deck when I generated the last .mlt file. I deleted all the stations and waterlines from Delftship and just set them for the export to Michlet. Attached works in Michlet. Should have checked the first one. I cannot go deeper than 130mm because the aft deck does not have much freeboard. Rick |
#634
| Vic I never had to touch the prop this year. Just momentary stop and the leaves/weed just peels off. Even stuff that wrapped around the prop when I cut corners and went shallow into growing weed. A couple of back and forth motions with the pedals, blade flick in and out and the weed gets thrown off. The folding prop is a big step in overcoming weed. It gives me more design freedom with locating the prop. Rick |
#635
__________________ Kenneth Grome |
#636
| Bubbles do work and this is a clever approach. Sometimes there is marine life we can mimic to increase efficiency. Like the olympic swimsuits that have ridges which mimic sharkskin? Porta Quote:
#637
http://nparc.cisti-icist.nrc-cnrc.gc.ca/npsi/ctrl?action=rtdoc&an=8895319&article=0〈=en
#638
| Seats Just changing the subject for a moment, have made a new seat and am using an inflatable cushion for lower back support. Tried it for the first time today and went for 1.5 hours with no aches. The cushion gave good support but also allowed movement when pedalling, the problem with the old one was sitting in one rigid position all the time. Does anyone else have seat problems? Ian |
#639
found your description and photos by chance. Seems we share a lot of ideas and preferences! I did some work on my seacycle twin in order to make it fit for multi day excursions. Best greetings Clemens |
#640
| Cruising Seacycle Hello, I'm new to this forum, signed in today, after Rick sent me the link to this very interesting thread. Thrilled about your modified Dart catamaran! Three years ago, I modified my seacycle twin in order to transform it into cruising vehicle. After a 2 day trip to the canal connecting the rivers Rhine and Marne I added another platform section to put up a small tent on the deck. I made several 3 day excursions on Lake Konstanz, Germany. Next I'd like to make a lighter and wider platform of foam, epoxy and fibre glass / carbon fibre. Enclosed you'll find a report in Velo Vision. Cheers Clemens Quote:
#641
| Clem Have you made any plans for the deck modification? Are you only in the thinking stage or have you got a finish date in mind? Rick W |
#642
| New platform / deck for Seacycle Rick, so far, I only did some sketches. It would be great to test the new configuration in June. Will send layout soon. My goals:
#643
| Clem There is some free 3D CAD software called Delftship that can be used for drawing up things like you propose so you can visualise them. It also allows you to get accurate measurements of pieces. Takes a little bit of learning but is worth the effort if you do not have access to other CAD software. It can be a challenge to get children to join you in the things you like doing. As they get older they have their own interests. I think you would have a special child who enjoyed pedalling on the water. Rick |
#644
| Great report, great effort. Thanks for sharing, Rick. Is there any merit to a pulling folding prop that might not require a strut? |
#645
Rick |
| Propellor for pedal powered catamaran | Tiny Turnip | Props | 15 | 02-05-2012 07:27 PM |
| Electric motors for solar-powered boats | Twointense13 | Boat Design | 3 | 01-07-2011 08:21 PM |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| Human-powered boats and submersibles | RatliffFranklin | Boat Design | 0 | 05-08-2007 01:36 PM |
| Bugatti engine powered boats | rivaaquarama | Powerboats | 0 | 06-08-2006 04:26 PM |
