#571
| Pedal morphology Here is a link to a breakdown of some of our family race boat ideas we gave points for creativity: http://www.designwizardry.com/pedalb...ndex2004.shtml I thought "Randy's" was coolest but "Long Johns" was always fastest.
__________________ rambat |
#572
| Looks like fun was had by all! I reckon the coolest has to be the squirrel cage thing in you post. Nick |
#573
This is pertinent to a recent question. Is he still around? I would be interested to know how he describes the sensation pedaling with a shaft like this. Rick W |
#574
| Yes, if this could be geared up somehow, and the wheel made lightweight and streamlined, might be fast. It depends on water friction for propulsion and goes faster the higher the water friction is. So it uses water drag to go faster instead of fighting it as most streamlined boats attempt to do. But it is fighting displacement with a very short hull "length" which would slow it down. The "hydrocopter" uses a similar principle but is very fast because it rides above the water without displacement being an issue. Porta |
#575
| Here's something interesting along the lines: http://www.youtube.com/watch?v=Psyl-AQ0m2A Porta Quote:
#576
| Vic It gets back to the Bob Stuart's tracks because the buoyant part needs to be long and slender to reduce wave drag. One of the interesting things that I never really thought about until Leo Lazauskas provided a paper on it is that hovercraft suffer from wave drag. The efficiency of the craft can be improved by altering the shape of the pressure field for different speeds. Point is; wave drag is an issue even when the craft is not in direct contact with the water. On the big wheel boat the viscous drag provides the propulsion but the wave drag is a killer. Worse than trying to ride a bike through sand. However turn it into a long slender tube in the form of a continuous track and you would have something much more efficient. It needs to be built. Rick W |
#577
#578
The minimum drag hull for human power uses about 90% of the power to overcome skin friction. There is only 10% going into making waves. If skin friction could be reduced there would be a huge gain in speed. If a system could be engineered for bulk carriers it would save vast quantities of fuel. Rick W |
#579
| Start blowing bubbles under the hull it will dramaticaly reduce friction drag and has already been done on ferries |
#580
I recall seeing pictures of a single ox pulling a barge along a canal. The barge looked large enough to carry the equivalent of what ten two-ox carts would carry. |
#581
| It still is much more efficient than anything else because of the size of loads it can carry otherwise i might bet on the train. |
#582
I have not thought about the break even size with a boat where the rolling friction would cost more than the viscous friction. It might be quite small vessel. Trains go to a lot of effort to reduce rolling drag and windage is lower than road transport. It would be an interesting analysis. One of the problems with the buoyant belt idea is the air drag on the return strand but it would be much less than the water drag at the current speeds of interest. Rick W |
#583
| Twist Quote:
#584
It gets rid of the inherent problems with paddle wheels as well.Surely with modern materials this could be done. |
#585
| Surface Piercing? The only mention I found in this thread about SPP was that weed could be cleared by half-lifting the prop, yet SPP seems to have a lot going for it (might clear weeds for a start!) . Is there any reason why this is not being used? |
| Propellor for pedal powered catamaran | Tiny Turnip | Props | 15 | 02-05-2012 07:27 PM |
| Electric motors for solar-powered boats | Twointense13 | Boat Design | 3 | 01-07-2011 08:21 PM |
| Windmill or Wind Turbine- powered boats: how many are out there, and are they viable? | Duma Tau | Projects & Proposals | 503 | 08-13-2010 02:00 PM |
| Human-powered boats and submersibles | RatliffFranklin | Boat Design | 0 | 05-08-2007 01:36 PM |
| Bugatti engine powered boats | rivaaquarama | Powerboats | 0 | 06-08-2006 04:26 PM |
