Old 07-18-2010, 01:35 PM
Bahama Bahama is offline
Rep: 20 Posts: 85
Partial Skeg/Semi-Spade Rudder with Downward Slope and Ceramic Blade
I've been reading about partial skeg (also called semi-spade) rudders; they are supposed to provide some of the efficiency of a full spade rudder with the protection of a full skeg.
The only complaint that I see is that ropes can sometimes get caught in between where the skeg and rudder meet.
I was curious if anyone has ever sloped that joint forward and downward from the aft--that way if a rope did catch, it would stand a better chance of just sliding down and off.
And it would also be possible to mount a ceramic blade into that joint so that any rope would simple be cut... even wires would be cut with a ceramic blade because it's harder than they are, and it would keep its edge for a long long time unless it was cracked by some very strong cable (that would cause more damage to the rudder, so you wouldn't be sweating over the cracked blade).
If you've ever used a ceramic blade, they are incredible how strong and sharp they are. Just a thought.
Robber 3e rudder and skeg simon wheeler Boat Design 0 09-22-2009 08:58 AM
Gap between rudder blade and cheeks justSteve Sailboats 6 06-03-2009 01:22 PM
Does a sail act as a turbine blade or a propeller blade? ThinAirDesigns Boat Design 73 01-26-2009 05:43 AM
rudder blade Scofield Boat Design 2 04-02-2008 08:36 PM
4 blade prop,shaft,rudder & skeg $500 7393452 Marketplace 0 12-17-2006 08:23 AM
