Old 03-25-2010, 11:38 AM
Sceptre Sceptre is offline
Rep: 10 Posts: 35
Painting question o_O
Im planing on jus painting the top part of my boat just for this summer what do you guys recomend what type of sanding paper do I need and should I paint it with a spray air gun or with a brush ?
Old 03-25-2010, 01:05 PM
Rep: 749 Posts: 1,314
What kind of boat do you have? Wood, glass, aluminum, other...? How is the boat stored? Under cover or outdoors? How big is the boat? Are you talking about paint or varnish? More information is needed before you can get good answers.
Old 03-27-2010, 10:42 AM
Rep: 10 Posts: 35
16 ft fiberglass chrysler i store indoors i dont really care if it lasts a year as long as it lasts this summer jus paint the old one is alwready yellowish
Old 03-27-2010, 11:28 AM
If the deck is in reasonably good condition, that is to say that it does not have a lot of gel coat cracks, then the process is simple but laborious. The surface may be chalky. That has to go. Wash thoroughly, sand the surface with 230 grit paper. Wet or dry type sandpaper, used wet, is the better plan. If you use wet or dry, put a few drops of dish detergent in a bucket of water. Use that water to keep the sanding surface wet. Rinse the sandpaper in the bucket frequently. What you are trying to do is prepare the surface by smoothing it and leaving a light matte finish on the part to be painted.
Rinse thoroughly with fresh water. Let the decks dry until no moisture is present. Inspect the surface for sanding residue, you will probably find some here and there. Wipe off the residue. A good epoxy primer is the next step. Follow instructions on the package. You can brush this on but you should not do it in the hot sunshine. find a cool shady place. Do not be stingy about buying a good quality brush for this job. Do not apply the primer too heavily, just try to do it smoothly.
When the primer has cured for a day or two you can proceed with the finish coat. Epoxy will stick to the fiberglass whereas many paints will not. Well not for long anyway. There is a problem with epoxy that you need to know about. The problem is that it does not endure UV radiation very well. It'll soon become chalky if exposed to a lot of sunshine. That is why you use a finish coat over the epoxy primer. Finish coat can be any good oil based paint. To be sure, some oil based paints are better than others but almost any name brand will do. If you do not mind the expense then get some so called boat paint from your friendly marine supply dealer. Those specialty paints are reliable but cost more than something that you might get at the hardware store or paint supply store. If you have a Sherwin Williams store in your area, then consult them. Their paint is not cheap but it sure does not cost as much as "marine grade" and it will do just as well.
If you do a decent job of this you can expect your paint to last several years. If you use epoxy primer you will need some epoxy solvent to clean that nice brush that you bought. You will need some solvent for the finish coat paint too. That will probably be simple mineral spirits. Epoxy uses butyl cellusolve or similar. Laquer thinner will work for cleaning but not as well as the epoxy solvent. After each solvent brush cleaning session, spend some time on your brush with soap and hot water. Use a coarse bristle scrub brush or a comb to work the soap into all the places that paint tends to hide inside that nice paint brush. Rinse carefully and hang it up to dry.
Good luck, and remember that these solvents are highly inflammable. Use caution. Do your painting in a well ventilated place or do it outdoors.
Old 03-27-2010, 11:38 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
I'd suggest a single-part urethane like Petit or Interlux make. Prime with their recomended primer and sand to 320 prior to top-coating (two coats min).
Brushing is no problem----- read what you can about brushing a urethane paint.
What matters most is whether or not you are an experienced painter. If not, you had better find a friend who is skilled in laying on paint. Painting is like playing guitar. Everyone does it but very few are really talented.
Old 03-28-2010, 12:31 PM
Rep: 10 Posts: 35
that was most deff best reply i got on this website thanks a lot but do i use the air gun or a brush to do the finishing layer
Old 03-28-2010, 12:38 PM
Rep: 10 Posts: 35
well like i said as long as it lasts me a year id be happy because right now it looks jus yellow old instead of white
Painting Question chry sport fury Boat Design 5 08-29-2009 05:17 PM
Painting Question chry sport fury Boat Design 0 06-15-2009 05:53 PM
epoxy painting question? plurpimpin Wooden Boat Building and Restoration 2 07-25-2008 07:06 AM
Painting with Awlgrip question ronc98 Materials 6 10-21-2007 11:00 PM
Painting ? dansea Materials 4 09-26-2004 10:13 PM
