Old 11-09-2011, 11:00 AM
sean-nós's Avatar
sean-nós sean-nós is offline
Rep: 286 Posts: 103
P bracket---- strut help
Hi guys I am building a crackerbox as you can see below one of the problems I have is the strut I got with the donor boat is a bit short and if I move it forward on the shaft to meet the hull I think the gap between the strut and the prop will be too big at about 3" another thing I could do is raise up the base of the strut on a bit of wood and taper it to the hull but that may work like a trim tab that I might not need,so before I splash out for a new strut any ideas on how I could make this work
Also I have seen these on the internet are they any good for speedboats as I think it would be easy to set up the shaft angle and then just fix the strut in place. Thanks for any help
Old 11-09-2011, 07:23 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,864
Can you alter your engine alignment.
If not I would make a wedge from fibre glass and bolt it up, make sure the engine has some adjustment after wards.
A more drastic aproach would be to cut the bracket and re weld.
The bracket will be 15 degrees as that is the normal angle and the engine should be 15 degrees to match it.
Old 11-10-2011, 04:11 AM
sean-nós's Avatar
Rep: 286 Posts: 103
Thanks for the reply Frosty as you can see on my mock up I cant drop the engine any more and if I raise the angle of the shaft the prop will very close to the hull less than 1"
A wedge would have to be 1 1/2" high to mate the strut to the hull and with the thickness of the strut base that would be 2" in all of a taper.
Old 11-10-2011, 05:50 AM
Frosty's Avatar
You need to drop the front and raise the back to bring the shaft up to the hull. Those mount are perfect for the job.
Stainless V Strut vs Bronze V Strut jameshogan Materials 7 05-17-2009 07:03 PM
Strut repairs buckknekkid Inboards 3 05-18-2007 04:47 AM
Strut alloy ABoatGuy Propulsion 2 01-09-2006 08:44 PM
Strut Calculations Timm Propulsion 12 10-10-2005 01:03 PM
strut suppliers? drs3317 Propulsion 1 08-16-2005 01:17 PM
