Old 12-11-2002, 12:02 PM
JPigott JPigott is offline
Registered
Rep: 10 Posts: 27
Outboards and Short Range Offshore
Just interested if anyone has answers to these questions.
It seems you see more offshore type outboard powered boats. I was just trying to address two issues.
1) how could the possibility of swamping the engine be reduced. I had planned to add a kicker rather than dual outboards but still with good seals how does the outboard run into trouble.
2) If I needed to back down on a larger fish what could be done to reduce waves coming over the stern. I considered trim and stern angle as well as (probably to complicated or causes other problems) a tiltable rear swim like deck?
Thanks in Advance.
JPigott
Old 12-11-2002, 11:41 PM
badges65 badges65 is offline
Registered
Rep: 10 Posts: 62
Hi,
not much you can do.. you have to use long shaft motors which give a few more inches of height ..
wouldnt try anything like a movable system prone to failure..
when you have fish on you dont backup with outboards you have to work in a circle around the fish.. fishing off the quarter of the boat rather than over the stern !!!
don
http://invertedvboats.741.com/
http://ivb-boats.netfirms.com/
Old 12-16-2002, 09:53 PM
Timm Timm is offline
Rep: 64 Posts: 107
If it is a center console, chase the fish in forward, fishing from the bow. It is alot safer for both you and the boat!
Old 12-17-2002, 04:44 PM
Registered
Rep: 10 Posts: 27
Thanks guys!
Old 12-31-2002, 05:44 PM
Schoonertack Schoonertack is offline
Rep: 10 Posts: 25
outboards
If I was to go offshore an outboard is a non issue with modern saltwater outboards. Backing down on a fish with two props wipping the water is very problematic. Tight lines and keep the fish forward, I know it takes some boat handling most outboards want to drift bow down wind, but just how far aft can you keep your lines when you stand forward of the outboard well with a good bend in a boat rod? I can't either!
Old 01-03-2003, 09:40 PM
Registered
Rep: 10 Posts: 27
Schoonertack.
Thanks. One less thing to worry about. One more for consideration.
Bring the warmer weather!
JPigott
