Old 08-10-2011, 10:37 PM
diego1 diego1 is offline
outboard yacht
I was planning to build a yacht, possibly a sport fisher or a power catamaran. The only problem is that her is king of difficult to install an iboard engine do yo know if it is possible to intall multiple outboard motors on a yacht (sportfish or cat...) between 45 and 65 feet long. COuld you put links and examples if you got.
Thanks.
Old 08-11-2011, 12:05 AM
FMS FMS is offline
Rep: 125 Posts: 233
Sure - the Intrepid 47 comes to mind:
http://www.boatingmag.com/intrepid-475-boat-year
http://www.boattest.com/boats/boat_video.aspx?ID=1512
http://www.yachtingmagazine.com/article/Super-Sled
Old 08-11-2011, 04:41 AM
Rep: 3125 Posts: 9,398
Why is it difficult to install inboards in Peru? How about out drives? Two 550 HP diesel out drives on an Intrepid would be much more economical and probably faster without the extra two legs dragging in the water. The Mercury 275's are 20k apiece, before controls, so that's 80k. I can pick up two 500 HP Cummins right now for about 50.
Old 08-11-2011, 12:45 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 707
isn't the main feature of the Intrepid 47 that you easily go on
less than all four motors and trim the others up out of the water?
The first story said something about 'cruising at 50+ or fishing at 0.8 gph'.
I assume the 0.8gph is on one motor.
Wouldn't the Speed VS GPH spreadsheet for the Intrepid 47 need a few more pages, for various combos of # of motors in the water?
What would be better, two inner motors or just two outer motors?
Old 08-11-2011, 03:27 PM
What would be better is the dramatically reduced drag of a single drive leg of the HP required to hit their target S/L. Having 4 legs in the water is just silly. On a vessel this size 2 can be justified and one is the optimum.
Outboard Well vs. Slide for Outboard Mounting? CatBuilder Outboards 17 06-09-2011 07:07 PM
3D Yacht Renderings - 44.18m Sailing Yacht by Dubois Naval Architects & Alloy Yachts urbanvoyage Boat Design 2 06-17-2010 01:44 AM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 03:54 AM
mounting outboard to inboard/outboard pcromien Powerboats 25 03-03-2007 11:46 AM
Ducted Propeller on Retractable Outboard for Sailing Yacht ? Seabury Propulsion 6 11-22-2006 12:38 AM
