Old 06-08-2008, 08:30 AM
Bullshipper Bullshipper is offline
Bullshipper
Rep: 21 Posts: 40
Outboard Transom Angles??
I am looking for the recommended hull transom angle for Yamaha outboards 115-225hp, and find nothing when I look at the oem's stuff or google.
I assumed it was about 14 degrees on a boat that rides level (catamarans), and about 11 degrees on monohulls with a 3 % keel rise when going slow.
Can anyone help me out?
Old 06-09-2008, 01:56 AM
Rep: 1493 Posts: 7,447
14 degress is the nominal dimension. However, that means it gives you enough to trim the engine in for better hole shot, and then you should trim out as the boat planes.
Old 06-09-2008, 03:10 AM
hmattos hmattos is offline
Rep: 59 Posts: 115
Here at Explorer Marine - www.explorermarine.co.uk - we used to build to 12 degrees in the 1990s, but as engine hp has increased and tilt and trim systems have improved, we have now moved to 15 degrees where the engine is mounted and then extend the planing surface back to improve handling and minimise bow lift.
We usually fit 115 - 150+ hp Evinrude ETEC or Suzuki DF on RIBS from 4.5 to 10 metres.
Hope this helps
Hugh Mattos
Old 06-09-2008, 07:49 AM
Bullshipper
Rep: 21 Posts: 40
Thank you both very much.
The boat I am designing needs to back down well for large fish species, so I think I will try 16 degrees on the prototype, realizing that these motors have more range tilting up than down
Transom Reinforcement for Outboard Conversion Jim Williams Boat Design 25 10-04-2009 10:38 PM
military bidge boat the transom has no angle what is the best way to attach outboard? o2bfishn Metal Boat Building 3 06-18-2008 10:26 AM
Zero draft angles and moulds Dresca Materials 4 04-15-2008 03:16 AM
Transom reinforcing 34 Silverton for outboard conversion naturewaterboy Fiberglass and Composite Boat Building 18 07-16-2007 07:23 PM
Transom thickness for outboard motor 100 to 250 hp hseneque Boatbuilding 2 08-19-2005 11:39 AM
