Old 06-27-2006, 10:05 PM
designdreamin designdreamin is offline
Outboard rudder vs. inboard rudder
Looking for a pro's and cons list, mainly performance oriented, on outboard versus inboard (under hull) rudder.
boat type: A pretty light ficticious sport sailboat D/L is less than 100, boat could plane at times downwind or hot reaching. SA/D over 25. Ballast to disp ratio of around 40%, moderate beam to length, not narrow but not wide.
just general thoughts to get things rolling. I appreciate the help.
Performance pro's and con's
outboard pro's
I'm told farther away from the keel. but why is that important.
more direct feel?
Can make a narrow rudder due to no rudder stock. but why is this important and doesn't a rudder too thin harder to drive in the groove...or is it easier?
Outboard cons
ventilation? But what exactly is this and doesn't a inboard rudder experrience it anyway? At what point does it happen and can the driver prevent it? If the boat is sailed without a lot of weather helm isn't it a mute issue? Flat is fast???
Inboard pro's
balance? But can't a outboard one feel balanced?
inboard cons
short "wheelbase" hencec turning radius or feel?
Again I'm just getting things started, I hope someone can come up with a better organized pro and con list of both. I am just looking for a general education on this.
I apprecaite the responses. I understand being "new" to the forum and asking a quesiton that was covered before can be frustrating for regulars. I tried to search but couldn't find a direct discussion.
mounting outboard to inboard/outboard pcromien Powerboats 25 03-03-2007 11:46 AM
Rudder Angle And Effective Size Of Rudder... saildog Sailboats 5 03-06-2006 03:34 PM
Rudders - What spec's are needed to build a rudder for an inboard? AlaskaFisherman Powerboats 0 10-08-2005 07:48 PM
outboard as in inboard? tryin to float Boatbuilding 17 08-12-2004 10:04 AM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 03:36 PM
