Old 06-11-2008, 07:02 PM
raymizzi raymizzi is offline
Rep: 10 Posts: 8
Outboard installation
Need some advise to install a 25hp on a Cyber 370. Are there any hints about the distance between the center of the prop and the bottom of hull?
Old 06-19-2008, 12:09 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
The simple answer ( I dont know what a cyber 370 is so i'm guessing displacement) is the whole prop needs to get clear water from the hull so the cavitation plate needs to be level with the bottom of the aft part of the hull.
You may still need to go lower then this to prevent the prop sucking air down from the surface.
Old 06-19-2008, 08:42 AM
Rep: 10 Posts: 8
If you visit Youtube 'Cyber 370' the boat No.88 is my son"s boat . Aout the height we have just lifted the engine about 25mm so that the cavitation plate is now the same level with the bottom of the boat. Do you think that how it was the engine gives less revs and now higher revs ? Thanks and regards
Old 06-19-2008, 09:12 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Yes, less drag, more speed and more rpm's..
Tom Lathrop
New installation GWB Electrical Systems 3 03-24-2008 12:05 PM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 03:54 AM
outboard installation drawing ars-technica Boat Design 3 11-11-2006 04:47 PM
Sterndrive installation Danielsan Sterndrives 14 04-27-2006 07:01 PM
Knotmeter installation Danny Sailboats 8 05-17-2005 11:34 PM
