| Optimum Scow bow angle? I am designing pontoons with a flat scow front. Is there an optimum angle for a scow front end? This houseboat will operate in an inland lake and not over 10 mph hull speed. Also, which would be better-- a narrower deeper hull, or a wider shallower hull? Does it matter? |
| No optimum angle. Just better than totally bluff. As for wide shallow deep etc , you are better with a wider hull for the best stability since it is all form stability with this sort of application. But there's not much to go on ! Any concept sketches , numbers ?
| The more rake (angle) the less displacement. The less weight capibility in the bows. At 10 mph, you won't have much bow wake. 45 degrees is a easy one to work with. How much total weight will these 'toons need to cary? How much freeboard do you want when fully loaded? Knowing these 2 things will let you play with the displacement equation & get a better idea of the shape of the hulls
| Large Sailing Scow | bblair | Boat Design | 51 | 01-27-2012 07:55 PM |
| Scow moth....fun looking boats | alyne | Sailboats | 8 | 06-02-2011 01:28 PM |
| Optimum Forestay Angle | PI Design | Sailboats | 3 | 11-08-2006 09:54 AM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 03:14 PM |
| Optimum heel angle | Blether | Sailboats | 9 | 06-09-2004 07:46 AM |
